Judie
#1 Posted : Thursday, January 29, 2009 7:51:18 AM(UTC)
Judie
This MW fits in a custom space above my stove....not easy to replace.
MW works fine except for the top half. It hasn't worked for some time but now I feel like fixing it. Does the smart board cover all the controls? What else could it be since as I said the bottom half has no working issues. I see you sell a smart board and I have taken the unit apart (unplugged) and I see this is easily put in with the snap on connectors. What are your thoughts on this.
#2 Posted : Thursday, January 29, 2009 9:03:07 PM(UTC)
Judie,
Can you explain more specific what did you call "the top half" and "the bottom half"?
Judie
#3 Posted : Friday, January 30, 2009 1:57:03 AM(UTC)
Judie
Judie,
The top half is the sensor area there are 10 things they are popcorn, meat, chicken pieces, potatoes, etc. You press your choice it comes on then it errors. there is a line and then there are other choices like micro cook,
time defrost, auto defrost, temp cook, auto roast and under there are he numbers, clock, start, etc. all of these work. Its the top part that doesn't work. Does this help I have tried all the things in the booklet when it errors to reset etc. nothing works.
#4 Posted : Monday, February 2, 2009 11:57:08 AM(UTC)
Judie,
Sounds like the problem is a bad key panel. In order to provide the right part number I need the color of the key panel.
#5 Posted : Monday, February 2, 2009 3:08:29 PM(UTC)
Judie,
The part number for the white key panel assembly is AP2026295. This part is on back order. Call the customer service at 877-477-7278 to find the ETA.
Inside colors are not important at all.
Microwave fuse blows out frequently (Microwave Repair)
by Guest 6/15/2024 4:55:42 AM(UTC)
LG LMV1680ST Microwave Door Switches (Microwave Repair)
by ctalbert150 6/13/2024 7:19:37 AM(UTC)
Whirlpool Oven/Microwave combo E1 F2 (Oven Repair (including Ranges and Cooktops))
by MalcolmR 6/12/2024 10:02:00 AM(UTC)
Solved: Removing microwave unit from wall mounted Oven/Microwave combo (Oven Repair (including Ranges and Cooktops))
by MalikR 6/10/2024 3:04:18 PM(UTC)
Whirlpool Gold Accubake Oven/Microwave (Oven Repair (including Ranges and Cooktops))
by Guest 6/10/2024 10:21:28 AM(UTC)
How to pull microwave out of mw/oven combo (Oven Repair (including Ranges and Cooktops))
by cromking 5/6/2024 1:13:05 PM(UTC)
Microwave goes dead when hot (Microwave Repair)
by Guest 5/5/2024 8:05:15 AM(UTC)
Door Switch Help With Samsung Microwave Model ME21M706BAS (Microwave Repair)
by clagrow 5/2/2024 6:28:45 AM(UTC)
GE PT7800SHASS Combination Microwave / Oven - Key Panel SHORTED (Oven Repair (including Ranges and Cooktops))
by RCAppl 4/23/2024 7:59:18 AM(UTC)
GE Oven - Microwave/Oven PT7800SH2SSA (Oven Repair (including Ranges and Cooktops))
by Guest 2/13/2024 11:22:12 AM(UTC)
Kenmore Pizza Oven Microwave (Microwave Repair)
by mwjkmail 2/3/2024 5:10:49 PM(UTC)
Kitchenaid (Whirlpool) Microwave door switches (Microwave Repair)
by ForumUser1 1/11/2024 1:11:07 PM(UTC)
Whirlpool Microwave Lower Bulb will not turn on (WMH31017HS08) (Microwave Repair)
by Axtell 1/2/2024 3:49:44 PM(UTC)
Kitchen aid electric wall microwave and oven (Microwave Repair)
by Guest 11/9/2023 8:15:09 AM(UTC)
Frigidaire Microwave PLMVZ169HCA (Microwave Repair)
by Guest 10/25/2023 11:02:01 AM(UTC)
