sgerry
#1 Posted : Monday, July 14, 2008 8:46:31 PM(UTC)
sgerry
the timer will not move to the next number to shut its self off it just keeps on runing this happens on the regular cycle as well as the permernant clycle.it will shut off if it is set less than 20 menints on permernant press cycle.
#2 Posted : Tuesday, July 15, 2008 4:37:29 PM(UTC)
The first thing I would do is make sure the exhaust line is clear and all air ducts inside the dryer are not clogged.
The model number you posted does not come up and I'm not able to provide more accurate advise.
sgerry
#3 Posted : Tuesday, July 15, 2008 9:36:41 PM(UTC)
sgerry
I LEFT A MESSAGE YESTERDAY ABOUT MY DRYER AND i RECHECKED MY MODLE # AND IT HAS TOO MANY O'S AT THE END.THE # is131717100.
thanks to Gene for answering,I did as you said and cleaned a lot of lent from the bottom of the lent trap and I thought It was going to work but it worked only for a little while then it got stuck again. Gerry
gas dryer wont shut off on sensor mode (Dryer Repair)
by m218perez 6/20/2014 7:26:43 AM(UTC)
estate dryer wont shut off (Dryer Repair)
by centerville1966 2/15/2014 1:39:29 PM(UTC)
Maytag dryer wont shut off after cycle (Dryer Repair)
by knzvet 11/3/2013 4:00:37 PM(UTC)
My dryer wont shut off on its own (Dryer Repair)
by tracy0821 12/23/2012 8:20:20 PM(UTC)
Maytag Dryer Wont Shut Off (Dryer Repair)
by mikeb104 4/7/2012 11:17:29 AM(UTC)
by craig97ss 10/1/2011 8:34:29 AM(UTC)
Dryer wont shut off when I open the door (Dryer Repair)
by Chad The Handyman 4/19/2011 6:14:58 AM(UTC)
dryer wont shut off by itself (Dryer Repair)
by bremark 3/4/2011 11:44:25 AM(UTC)
by jjm 11/9/2010 4:07:51 PM(UTC)
Gas Dryer Wont Shut off Automatically (Dryer Repair)
by garytk 10/9/2009 1:22:18 PM(UTC)
