the timer will not move to the next number to shut its self off it just keeps on runing this happens on the regular cycle as well as the permernant clycle.it will shut off if it is set less than 20 menints on permernant press cycle.
Groups: Senior Expert, Administrators Joined: 7/19/2007(UTC) Views messages in topic : 27,455
The first thing I would do is make sure the exhaust line is clear and all air ducts inside the dryer are not clogged.
The model number you posted does not come up and I'm not able to provide more accurate advise.
I LEFT A MESSAGE YESTERDAY ABOUT MY DRYER AND i RECHECKED MY MODLE # AND IT HAS TOO MANY O'S AT THE END.THE # is131717100. thanks to Gene for answering,I did as you said and cleaned a lot of lent from the bottom of the lent trap and I thought It was going to work but it worked only for a little while then it got stuck again. Gerry
