Replacement parts for lnc7766a71 models | AppliancePartsPros.comI do not have a wiring diagram for the unit so the below is a bit of a guess.
It sounds like a timer problem.
I am assuming the timer rotates past off to the next cycle.
Unplug the nit and open up the console.
The timer should have connections marked L and M.
L is power in (L1).
M is for the motor.
Remove the wire going to one of these. This prevents you from reading an alternate/parallel circuit path.
Now measure across the 2 connections.
When in a cycle, they should read 0 ohms (closed).
When at off,they should read infinity (open).
If they do not open then the timer is toast, the contacts are welded together.
Note: You may find the wiring diagram in the console, it is a favorite storage area for many manufacturers.
