AmanaLWM353W
#1 Posted : Tuesday, June 8, 2010 11:26:52 AM(UTC)
AmanaLWM353W
Hi all,
My washer started leaking from underneath the outer tub. Water is comming from the middle where the shaft goes up into the tub. I removed the agitator, drive bell, and the inner stainless tub. Now I am looking at the splined shaft which has a rubber "boot" around it, which sits right above the lint filter. My question is how do I continue my disassembly? I expect the leak is underneath the lint filter but I don't want to go prying on anything until I'm sure what to do next. I'm guessing a hub and seal kit might fix my issue but I won't know until I delve deeper. How do I remove the rubber "boot" and lint filter?
Many thanks, J.
AmanaLWM353W
#2 Posted : Wednesday, June 9, 2010 4:59:05 AM(UTC)
AmanaLWM353W
this is the washer repair forum right?
AmanaLWM353W
#3 Posted : Thursday, June 10, 2010 6:29:51 AM(UTC)
AmanaLWM353W
hello? Hello? hello?
AmanaLWM353W
#4 Posted : Friday, June 11, 2010 7:44:40 AM(UTC)
AmanaLWM353W
ok nice try this forum is rather useless
richappy
#5 Posted : Saturday, June 12, 2010 2:45:16 AM(UTC)
richappy
Sorry for the delay, us servicers are very busy.
You can go to www.applianceaid.com for info on this washer. Rather involved procedure for the tub bearing and seal replacement and you will need a special puller to remove the bearing.
Us servicers whince when we see this as it would eat up a lot of time to fiw while the washer is not worth the amount of labor cost to fix.
Whirlpool will not drain or cycle. No Obstructions. What next?? (Dishwasher Repair)
by RyGuy73 3/2/2020 6:29:56 PM(UTC)
Fridge won't start, what next??? (Refrigerator & Freezer Repair)
by gefricot 7/26/2016 10:39:13 AM(UTC)
Dryer still won't heat,what next? (Dryer Repair)
by BSTrue 12/16/2014 3:26:17 AM(UTC)
Dryer--No heat, continuity tests ok...what next? (Dryer Repair)
by davesharpe 1/5/2014 12:48:28 PM(UTC)
Bosch dryer won't heat - tested usual suspects, what next? (Dryer Repair)
by sinoed 9/8/2013 7:00:44 PM(UTC)
Ice covering evaporator coils . . . What next? (Refrigerator & Freezer Repair)
by Dale.1 7/9/2013 8:44:46 PM(UTC)
frigidaire wont drain, pump replaced - what next? (Dishwasher Repair)
by mh1078 4/1/2011 10:25:26 AM(UTC)
Maytag LAT5005AAE has new Lid Switch assembly but fuse continues to blow, what next? (Washer Repair)
by hankshiggs 2/1/2011 11:35:15 AM(UTC)
Replaced defrost thermostat, what next? (Refrigerator & Freezer Repair)
by jesus freak 7/16/2010 7:53:25 PM(UTC)
What Next? (Oven Repair (including Ranges and Cooktops))
by Pastor Ken 7/15/2010 12:47:06 PM(UTC)
Maytag washer drain unclogged, what next? (Washer Repair)
by L. Caldwell 6/10/2010 9:12:22 PM(UTC)
Overload, Relay, Capacitor Replaced What Next? (Refrigerator & Freezer Repair)
by lrich002 11/16/2009 2:56:48 PM(UTC)
What next??? (Dryer Repair)
by greeneyes49 7/6/2009 10:20:36 AM(UTC)
Replaced defrost heater...coils frosting over again..what next? (Refrigerator & Freezer Repair)
by Momto8 6/15/2009 12:59:11 PM(UTC)
GE Profile New Control Board...What Next?? (Refrigerator & Freezer Repair)
by gratefuldiver 4/21/2009 4:21:15 AM(UTC)
