RyGuy73
#1 Posted : Monday, March 2, 2020 6:29:56 PM(UTC)
RyGuy73
Hello I have a Quiet Partner II as well and can't figure whats going on. I can't find the correct manual online either to cross check the specific model# of my dishwasher as It doesn't say anything on the washer itself other than Whirlpool Quiet Partner II. I found manual under bottom kickpanel. Looks to be Whirlpool part No. W10130990C.
My second question is; the Quiet Partner 2 will not drain, or go into any cycles. Buttons don't seem to get any response whatsoever. I cleaned up all the sitting water and excess debris. Took apart strainers sitting on bottom and the sump rotates freely no major obstruction and no major obstructions in drain pump, spins free both ways. I was getting the two most left LEDs blinking solid on and off together. (believe its pots&pans, and normal where blinks). After cleaning and unplug replug, Far left LED was solid stay light. Then pushed Heated Dry, Normal, Heated Dry, Normal. The two left LED's started alternating blinks. Should I first change the turbity sensor. If that doesn't fix what would be best to do next? Someone please send me the correct literature.
Robertboyer
#2 Posted : Tuesday, March 3, 2020 10:59:28 AM(UTC)
Robertboyer
I insist you take some technical advice from a technical professional. You can approach Appliances Repair Concord, as they are the best and most experienced kitchen repair services providers in the region of Concord, United States at very cheaper rates. They have also provided a Free consulting contact number on their website. you can reach them by clicking this link below:-
Appliance repair concord
