Schnidly
#1 Posted : Friday, May 23, 2008 10:40:13 AM(UTC)
Schnidly
Dear Sirs,
I own the above model Frigidaire, can anyone tell me how to check the dual element switch? Both the inside and outside burner comes on no matter which direction the control knob is turned. Also, can someone give me directions on how to replace the old switch with the new one, are there any concerns for me to understand before tearing apart the back panel of the range? Also, does someone know how to calibrate the oven? I dont have a thermometer that reads that high to calibrate with, any suggestions?
Thanks so much
#2 Posted : Friday, May 23, 2008 2:21:36 PM(UTC)
According to your description of the problem with the dual element the switch is bad and does not need any further diagnosis.
In order to calibrate the oven temperature you have to have a good oven thermometer.
- The part number for the dual element switch is AP2141123
SOS - Frigidaire Electric Range not working (Oven Repair (including Ranges and Cooktops))
by Pete11 1/27/2015 8:23:19 AM(UTC)
Frigidaire Electric Range F3 fault code (Oven Repair (including Ranges and Cooktops))
by utahmom 3/31/2014 12:26:01 PM(UTC)
My Frigidaire Electric Range is showing F1 Code. (Oven Repair (including Ranges and Cooktops))
by smieri6 7/20/2013 9:45:09 PM(UTC)
frigidaire electric range (Oven Repair (including Ranges and Cooktops))
by PITMAN 9/29/2011 7:44:11 PM(UTC)
Frigidaire Electric Range - Oven just blew - Top works HELP (Oven Repair (including Ranges and Cooktops))
by Kris&Tara 4/3/2011 6:14:12 PM(UTC)
changing ECU in frigidaire electric range.. quick question (Oven Repair (including Ranges and Cooktops))
by larryk13 3/22/2010 2:52:24 PM(UTC)
Frigidaire Electric Range-- controller 'brains' (Oven Repair (including Ranges and Cooktops))
by larryk13 3/19/2010 7:52:08 AM(UTC)
Frigidaire electric range temperature fluctuations (Oven Repair (including Ranges and Cooktops))
by faisalmali 11/25/2009 4:23:09 AM(UTC)
Frigidaire Electric Range and Cooktop (Oven Repair (including Ranges and Cooktops))
by bboustany 11/7/2009 11:24:31 AM(UTC)
Frigidaire Electric Range (Oven Repair (including Ranges and Cooktops))
by billfvib 5/31/2009 10:54:38 AM(UTC)
by billfvib 5/31/2009 10:50:40 AM(UTC)
1975 Frigidaire Electric Range (Oven Repair (including Ranges and Cooktops))
by BHERNANDEZ3 2/2/2009 7:13:30 AM(UTC)
