donnie
#1 Posted : Tuesday, September 4, 2007 4:57:21 AM(UTC)
donnie
MY PROBLEM WITH MY WHIRLPOOL DUET WASHER ONLY BEGAN WHEN WE RECIEVED A FLASH FLOOD IN ARE BASEMENT LAST WEEK AND SOAKED THE MACHINE UP TO THE DRUM CLEANED MOTOR,CCU AND ANY OTHER PLUGS AND PARTS I COULD WILL POWER UP BUT KIND OF SEEMS LIKE IT IS STUCK IN A CYCLE THE DOOR WILL NOT UNLOCK BY USING ANY CONTROLS ONLY WAY IS MANUALY IS THIS CONNECTED DIRECTLY WITH THE CCU? I SPRAYED WITH ELECTRICAL CLEANER LOT OF MUD IN THE WATER ANY HELP WOULD BE APPRECIATED ARE INSURANCE DOES NOT COVER ARE DAMAGE WE ARE CRUSHED TO SEE ARE WONDERFUL MACHINES SITTING THERE IDLE. dONNIE:confused:
tianaynay1973@yahoo.com
#2 Posted : Sunday, December 30, 2007 2:45:38 PM(UTC)
did you ever figiure out what was wrong. I am having the same problem with mine
donnie
#3 Posted : Sunday, December 30, 2007 5:04:52 PM(UTC)
donnie
Cleaned Up Wiring And Motor With Electrical Cleaner And Grease For Electric App,replaced The Ccu Machine Has Been Running Perfect Since Then Still Have To Get To The Dryer Though. Donnie
donnie
#4 Posted : Sunday, December 30, 2007 5:11:59 PM(UTC)
donnie
Also Dig Your Great Manualout For Technicians And You To Be Helped In Trouble Shooting The Machine It Should Be On The Inside Panel Of Your Washer Taped In A Plastic Bag This Tells You The Diagnosis For Your Troublcodes It Is Very Helpful Let Me Know How You Make Out Good Luck Help With Any More If Ican. Donnie
richappy
#5 Posted : Monday, December 31, 2007 3:41:17 AM(UTC)
richappy
I would put a heater near the unit and blow dry for a day. Also, disconnect all connectors and clean with a non-residue spray. Also, you can pry off the top of any relay that got soaked and clean.
Whirlpool duet washer front load (Washer Repair)
by Guest 6/3/2024 9:57:09 AM(UTC)
Whirlpool Duet Washer - Possible Faulty Fill Valve (Washer Repair)
by Guest 2/2/2024 4:18:21 PM(UTC)
Whirlpool duet washer not draining (Washer Repair)
by Guest 2/16/2022 8:40:23 AM(UTC)
Whirlpool Duet Washer - Wire broken off connector on harness (Washer Repair)
by Cephalon 1/21/2021 9:33:49 PM(UTC)
Whirlpool Duet Washer Codes (Washer Repair)
by mbocon 3/10/2020 5:04:51 PM(UTC)
Whirlpool duet washer (Dishwasher Repair)
by Julia Johnson 11/1/2017 9:53:41 AM(UTC)
What happened to my Whirlpool Duet washer?? (Washer Repair)
by colbran 10/2/2017 12:01:48 PM(UTC)
Whirlpool Duet Washer (Washer Repair)
by Bmbrouillette 7/2/2017 11:05:32 AM(UTC)
Whirlpool duet washer- won't start after replacing CCU and door latch (Washer Repair)
by Ivanick 5/22/2017 6:07:41 PM(UTC)
Whirlpool Duet washer FH code (Washer Repair)
by farmgirl 1/17/2017 7:14:25 PM(UTC)
whirlpool duet washer F06 E02 error (Washer Repair)
by tnafranklin 10/18/2016 12:47:55 PM(UTC)
whirlpool duet washer (Washer Repair)
by Oathose 4/4/2016 7:23:01 PM(UTC)
Whirlpool Duet Washer bellow tore in two. (Washer Repair)
by pitwoman 1/28/2016 5:42:42 PM(UTC)
by CrosbyFamilyFarm 12/31/2015 1:28:32 PM(UTC)
Whirlpool Duet Washer not working (Washer Repair)
by Shanej69 11/23/2015 1:59:18 PM(UTC)
