error code f6e2 not working tried to reset like it said unplugged it but nothing and it leaks around the gasket area of the door I beleive not happy with this machine at all
In my case I took the lower front panel off to access the pre- pump filter, layed a towel down, unscrewed filter cap. Cleaned and reinstalled. Run washer and error FH came up again. I shut off hot and cold valves and disconnected hoses at the back of the washer, found one of the hose screens completly blocked. I believe this will take care of the error code FH.
