ted
grosshaus
#1 Posted : Sunday, March 30, 2008 1:35:00 PM(UTC)
grosshaus
After the wash cycle my washer spins and drains for 2-3 seconds then stops. It continues to do this several times before reaching the next cycle leaving the tub full. Then the dial moves by itself to the next settings (permanent press, delicate, etc.) and repeats the 2-3 second pattern at each drain cycle. I checked for clogs ( I didn't take the pump apart) but found nothing. Any idea how to solve this?
#2 Posted : Monday, March 31, 2008 12:15:28 PM(UTC)
Hi Ted,
Most likely the problem is a bad timer.
- The part number for the timer is AP244688
Solved: Removing microwave unit from wall mounted Oven/Microwave combo (Oven Repair (including Ranges and Cooktops))
by MalikR 6/10/2024 3:04:18 PM(UTC)
Restricted airflow after repairman installed new blower wheel (Dryer Repair)
by Guest 6/1/2024 5:28:38 PM(UTC)
Water tube disconnected (Refrigerator & Freezer Repair)
by Guest 5/31/2024 11:41:13 AM(UTC)
GE PT7800SHASS Combination Microwave / Oven - Key Panel SHORTED (Oven Repair (including Ranges and Cooktops))
Belarus RCAppl 4/23/2024 7:59:18 AM(UTC)
Opened lid to add something to washer after it started and now the cycle won’t start again (Washer Repair)
by Guest 2/25/2024 6:18:56 AM(UTC)
Freezer holding at 22 degrees and ice maker (located in refrigerator cabin) isn't working (Refrigerator & Freezer Repair)
by eric5605 2/13/2024 4:35:48 AM(UTC)
GE fridge water dispenser slows to trickle, speeds up when filter is twisted (Refrigerator & Freezer Repair)
by Guest 1/11/2024 5:03:35 AM(UTC)
Ice Maker Arm trapped down, started to flood, Now won't work... help (Refrigerator & Freezer Repair)
by jimtmcdaniels 12/5/2023 7:20:56 AM(UTC)
Ge Monogram Integrated Top/Bottom Not Cooling ZICP360NXLH (Refrigerator & Freezer Repair)
by grundyv2 10/7/2023 12:48:51 PM(UTC)
Kenmore 665.17032403 Doesn't cycle to the heated dry cycle (Dishwasher Repair)
by breckrider 5/10/2023 8:01:43 AM(UTC)
Thermal fuse blown repeatedly (Dryer Repair)
by Guest 3/5/2023 6:13:36 PM(UTC)
Kitchenaid Control panel melted (Dishwasher Repair)
by Guest 12/9/2022 2:41:47 PM(UTC)
Downdraft range converted to ductless (Oven Repair (including Ranges and Cooktops))
by Guest 8/26/2022 11:42:42 AM(UTC)
LG fridge not cooling - freezer and ice maker fine - doesn’t look to be defrost related either (Refrigerator & Freezer Repair)
by Guest 7/25/2022 6:04:54 PM(UTC)
fan blade melted (Microwave Repair)
by chis 6/1/2022 9:32:50 AM(UTC)
