Everything on the microwave works but it stopped heating
If everything sounds normal but it is just not heating the magnetron tube is most likely bad. You would have test for voltage at the transformer to confirm but this can be dangerous so be careful. You have to make sure you are checking it on the low voltage side. This page will help with replacing the magnetron tube GE Spacemaker Microwave Magnetron Tube Replacement
