paris795
#1 Posted : 15 years ago
paris795
I have a kenmore range that worked fine.. recently a slight smell of gas from oven, confirmed with sniffer by gas man. Checked fittings with soapy water and resealed gas connection to range.Gas leak seems in frequent. Could a sticky safety valve be the problem? Please advise with possible suggestions. Can you please help!! Ive been laid off and can't really afford expensive service calls!! Iam handy and have meters and tools!
Signed really coul use a break!
DaRa
#2 Posted : 15 years ago
DaRa
Same symptom on mine. Gas man isolated safety valve. Big ticket item on mine. Oven installation instructions require L.P. pipe joint compound for gas connections.
gas leaking from burners and oven cavity (Oven Repair (including Ranges and Cooktops))
by MarisaCKD 5 years ago
Roper/Whirlpool dryer gas leak (Dryer Repair)
by STLDIYer 8 years ago
Gas Leak AFTER on for 15 minuets (Oven Repair (including Ranges and Cooktops))
by therealfleen 10 years ago
Gas leak smell from oven (Oven Repair (including Ranges and Cooktops))
by Aguilareagle1 11 years ago
gas leak (Oven Repair (including Ranges and Cooktops))
by michellejacobson@email.co 13 years ago
Gas leaking when oven is shut off (Oven Repair (including Ranges and Cooktops))
by charlieq3 14 years ago
gas leaks from base of burner (Oven Repair (including Ranges and Cooktops))
by Cyprien 15 years ago
My oven wont ignite after I tightened gas leaking connector (Oven Repair (including Ranges and Cooktops))
by raminla 15 years ago
gas leak from valve when dryer is off (Dryer Repair)
by drainpros 15 years ago
small gas leak/smell of gas (Oven Repair (including Ranges and Cooktops))
by jmarc 15 years ago
Kenmore gas stove W/ gas leak (Oven Repair (including Ranges and Cooktops))
by Snake 16 years ago
Magic Chef 3468xva gas leak (Oven Repair (including Ranges and Cooktops))
by indianfan79 16 years ago
gas leaking oven (Oven Repair (including Ranges and Cooktops))
by steinle 16 years ago
gas leaking after installing new glow igniter (Oven Repair (including Ranges and Cooktops))
by schimickn 16 years ago
by cesar0878 16 years ago
