paris795
#1 Posted : Monday, November 23, 2009 8:41:56 AM(UTC)
paris795
I have a kenmore range that worked fine.. recently a slight smell of gas from oven, confirmed with sniffer by gas man. Checked fittings with soapy water and resealed gas connection to range.Gas leak seems in frequent. Could a sticky safety valve be the problem? Please advise with possible suggestions. Can you please help!! Ive been laid off and can't really afford expensive service calls!! Iam handy and have meters and tools!
Signed really coul use a break!
DaRa
#2 Posted : Thursday, December 3, 2009 10:12:28 AM(UTC)
DaRa
Same symptom on mine. Gas man isolated safety valve. Big ticket item on mine. Oven installation instructions require L.P. pipe joint compound for gas connections.
gas leaking from burners and oven cavity (Oven Repair (including Ranges and Cooktops))
by MarisaCKD 6/2/2020 6:45:23 AM(UTC)
Roper/Whirlpool dryer gas leak (Dryer Repair)
by STLDIYer 7/20/2017 12:47:35 PM(UTC)
Gas Leak AFTER on for 15 minuets (Oven Repair (including Ranges and Cooktops))
by therealfleen 1/16/2015 9:48:47 AM(UTC)
Gas leak smell from oven (Oven Repair (including Ranges and Cooktops))
by Aguilareagle1 11/16/2013 11:46:06 AM(UTC)
gas leak (Oven Repair (including Ranges and Cooktops))
by michellejacobson@email.co 12/12/2011 10:10:22 AM(UTC)
Gas leaking when oven is shut off (Oven Repair (including Ranges and Cooktops))
by charlieq3 3/24/2011 10:04:10 AM(UTC)
gas leaks from base of burner (Oven Repair (including Ranges and Cooktops))
by Cyprien 6/24/2010 8:59:36 AM(UTC)
My oven wont ignite after I tightened gas leaking connector (Oven Repair (including Ranges and Cooktops))
by raminla 6/2/2010 12:14:35 PM(UTC)
gas leak from valve when dryer is off (Dryer Repair)
by drainpros 4/19/2010 8:14:56 AM(UTC)
small gas leak/smell of gas (Oven Repair (including Ranges and Cooktops))
by jmarc 10/7/2009 12:10:44 PM(UTC)
Kenmore gas stove W/ gas leak (Oven Repair (including Ranges and Cooktops))
by Snake 7/22/2009 12:50:33 AM(UTC)
Magic Chef 3468xva gas leak (Oven Repair (including Ranges and Cooktops))
by indianfan79 6/30/2009 12:05:07 PM(UTC)
gas leaking oven (Oven Repair (including Ranges and Cooktops))
by steinle 6/29/2009 8:30:26 AM(UTC)
gas leaking after installing new glow igniter (Oven Repair (including Ranges and Cooktops))
by schimickn 6/27/2009 5:56:54 AM(UTC)
by cesar0878 6/18/2009 6:53:10 PM(UTC)
