Alex1977
#1 Posted : Sunday, November 15, 2009 10:23:07 AM(UTC)
Alex1977
My GE JE2160SF Microwave is working normal other than the fact that it does not heat up. The display panel works fine. Any ideas please. Its my first time using a forum too.
SublimeMasterJW
#2 Posted : Sunday, November 15, 2009 2:06:44 PM(UTC)
SublimeMasterJW
The in line fuse is ok obviously so the low voltage stuff is ok. I would check the limit on the magnetron for continuity also the cavity limit and the mag itself. Any of these open and no heat. The mag ain't shorted or otherwise the barrel fuse would be blown and the low voltage stuff would not work so you are down to the cap or the diode. Since you gotta dig the cap and diode out replace em both is what I say. IF all the other stuff I mentioned is kosher that is. Here is a page that splains it a bit better with a cupla manuals fer ye to look at if you wish:
NUKE NOTES
gpedens
#3 Posted : Tuesday, November 24, 2009 7:22:44 PM(UTC)
gpedens
Alex, look here FREE Microwave Oven Repair and Fix Finder and read about safety precautions and discharging HV capacitor. Your wiring diagram is probably under the housing or outside cover. unplug the over and remove the cover.
You can test the diode with a fairly fresh 9 volt battery and a digital dc volt meter or multimeter. Most of these little meters dont care if you put the black or red lead on battery plus terminal. They will just show a negative voltage when connected backwards. Set scale to measure at least 10 volts DC. You only need to lift one end of the diode from the microwave , but removing it is ok too.
Connect one end of the diode to one of the battery terminals and the other end of the diode to one of the meter leads. Then connect the other meter lead to the other battery terminal. The meter should read about zero volts or about 4 to 6 volts. Reverse the diode connections. Your reading should reverse. That zero volts probably wont be zero but might be a few millivolts. In other words you should see about zero volts one way and 4 to 6 volts when you reverse the diode connections. The 4 to 6 volt reading may be -4 to -6 volts. If you are reading a negative voltage just swap the meter leads. A bad diode will give the same meter reading when you swap the diode connection. If it is burned open you will read zero volts or if shorted you will read about 9.5 volts or whatever the battery terminal voltage is.
Microwave does not Heat Food (Microwave Repair)
by newatappliancerepair 11/10/2016 10:53:37 AM(UTC)
Microwave does not heat (Microwave Repair)
by flynkites 2/4/2013 6:28:06 AM(UTC)
Microwave does not heat...buzzing sound (Microwave Repair)
by bnhmiles 3/15/2012 3:33:46 PM(UTC)
Whirlpool Microwave Does Not Heat (Microwave Repair)
by FixItManTim 7/17/2011 9:06:24 PM(UTC)
microwave does not heat (Microwave Repair)
by suzzan 4/30/2011 2:42:48 PM(UTC)
GE Profile Microwave does not heat any more (Microwave Repair)
by dealmaster 10/13/2010 3:21:06 PM(UTC)
my microwave does not heat (Microwave Repair)
by videomandw 8/16/2010 6:37:53 AM(UTC)
ge microwave does not heat, everything else works (Microwave Repair)
by shaunshaw 4/7/2010 10:36:03 AM(UTC)
Kenmore microwave does not heat (Microwave Repair)
by srikki9 9/7/2009 11:15:49 AM(UTC)
Microwave does not heat up. (Microwave Repair)
by Aliens1 5/27/2009 9:32:29 PM(UTC)
microwave does not heat, smells like its burning and buzzes (Microwave Repair)
by doogie48084 5/26/2009 10:58:40 AM(UTC)
by blackbeard1298 4/30/2009 4:50:12 PM(UTC)
Jenn Air Microwave does not heat (Microwave Repair)
by SpacemonkeyR 4/23/2009 5:52:19 PM(UTC)
by Kerryi 3/19/2008 1:46:51 PM(UTC)
by Bob Shuler 10/29/2007 7:55:21 AM(UTC)
