Guest
#1 Posted : Saturday, December 23, 2023 3:02:14 AM(UTC)
Guest
Groups:
I was given this washer which is model AWN432SP111TW01 with s/n 1106031978 for scrap price since it needed repairs. It was leaking at the main shaft seal and the bearing was very noisy . I dismantled it and replaced the worn out parts and am in the process of putting it back together. I have done this a time or two in the past and dread trying to hookup the support springs on the back side of the drum. I was told by my dealer who cant remember the source that there is a special tool someone made or is selling tp make it much easier to hook these springs on. Can anyone help me find this tool ? HELP HELP Help
Guest
#2 Posted : Saturday, December 23, 2023 7:03:10 AM(UTC)
Guest
Groups:
After some detective work my dealer came up with the p/n of the spring tool . It can be ordered under the p/n 00-321 P4. Price is aprx $10. It is a fairly simple hook type tool and I now have dimensions if someone want to make one. The rod is a piece of steel about 3/16" diameter and bent to form a handle at the top with a hook at the bottom. The overall length is about 15". Welding is suggested to form the handle. Contact me for details and a picture
Guest
#3 Posted : Sunday, December 24, 2023 10:27:47 AM(UTC)
Guest
Groups:
A secondary observation on this machine and quite a few other Speed Queen top load washers is that the styrofoam pad glued on the LH side of the sheet metal housing opposite the tub near the bottom is chewed up by the tub as it moves around during the spin portion of the cycle. This I presume is probably considered normal by the factory and the balance springs cant compensate for an unbalanced load of heavy wet clothes. On this particular unit I replaced the pad by gluing another piece of styrofoam in place where the older piece was located. There was no pad on the opposite side but I glued a piece there on the side wall of the sheet metal as I believe it is desirable. If anyone has some thought on this I would like to hear from you on this forum.
Speed Queen top load washer model AWN412SP111TW01 (Washer Repair)
by Guest 4/28/2024 6:36:53 PM(UTC)
Speed Queen top load washer model AWNE82SP113TW01 (Washer Repair)
by Guest 2/2/2024 10:12:50 AM(UTC)
Speed Queen top load washer modelAWN542SP111TW01 (Washer Repair)
by Guest 1/27/2024 10:43:32 AM(UTC)
Speed Queen top load washer model AWN542SP111TW01 (Washer Repair)
by Guest 1/13/2024 1:28:32 AM(UTC)
Speed Queen top load washer typical model AWNE82SP113 (Dryer Repair)
by Guest 12/1/2023 8:26:13 AM(UTC)
Speed Queen top load washer model AWS17NW (Washer Repair)
by Guest 10/16/2023 11:23:35 AM(UTC)
Speed Queen top load washer model AWN43RSN115TW01 (Washer Repair)
by Guest 2/5/2023 11:47:09 AM(UTC)
Speed Queen top load washer operation (Dryer Repair)
by Guest 1/29/2023 6:41:09 AM(UTC)
