Tom H
#1 Posted : Sunday, February 5, 2023 11:47:09 AM(UTC)
Guest
The above washer with s/n 1802054826 was given to me for possible repair by a neighbor. The unit would not start or run but there were no leaks or unusual noises. This design has no transmission but rather a motor and belt with the motor a reversing type. The internal circuit boards are the most complicated I have ever seen . I found the push-to-start switch on the panel corroded and the wire connectors leading to it also corroded. I replaced the wire connectors for the switch and temporarily bypassed it and got the unit to start and run. It runs through a normal cycle up the point of going into spin to get the water out. I cannot get it to spin out and cannot see any problem and would like to know if anyone has any experience on this model and where I should look next as a way to correct this unit. The troubleshooting I finally obtained is of no help so far except suggesting to call the dealer for service help. HELP !
