talbot
#1 Posted : 15 years ago
talbot
The machine works, but shuts off after a few minutes. The setting makes no difference; the dryer hums when the start button is pushed; the drum can be rotated eaily counterclockwise, but it is very hard to turn it clockwise; the belt is not broken, but it is starting to fray; once started, it gets noisier then shuts-off after a few minutes and cannot immediately be restarted. Any thoughts?
gabe_1981
#2 Posted : 15 years ago
gabe_1981
I believe its safe to say the motor is bad and needs to be replaced ... I have seen this same problem many times before and a new motor will have that dryer back up and running properly.
#3 Posted : 15 years ago
the drum can be rotated easily counterclockwise, but it is very hard to turn it clockwise;
The question is what is the normal direction of the drum. Check it in that direction. If it is hard to turn track down what is causing/jamming the drum.
Check the motor for bearing slop and give it a spin to see if it rotates freely.
heck that there is nothing in the blower wheel.
Your motor is overheating for some reason.
Could be the motor is toast as gabe_1981 said
Could be that there is too much load on the motor.
Could be that the motor is packed full of lint.
If it needs a motor I would also check all other moving parts, front supports, drum seals etc., best to do a bit of an overhaul on the unit. This will give you a total cost and then you can then decide if it is worth putting that many dollars into the unit.
Kenmore dryer problems after replace drum belt/idler pulley (Dryer Repair)
by Hspot 4 years ago
Cabrio dryer problems (Dryer Repair)
by artsalena 8 years ago
GE dryer problems (Dryer Repair)
by js072384 13 years ago
Dryer Problems (Dryer Repair)
by smartin349 13 years ago
by Mickey_951 13 years ago
by Tsailor 14 years ago
Dryer problems (Dryer Repair)
by Shoopes 15 years ago
Asko condenser dryer problems (Dryer Repair)
by Marv Sumner 15 years ago
Dryer problems mikeo (Dryer Repair)
by mikeo1899 16 years ago
by berniefl 16 years ago
Dryer problems HELP (Dryer Repair)
by MizzJessica 16 years ago
by mbgrdido 16 years ago
by janezucker 16 years ago
Roper Dryer problems (Dryer Repair)
by b0001744 17 years ago
by Myles.Smith 17 years ago
