smartin349
#1 Posted : Sunday, January 1, 2012 6:35:54 AM(UTC)
smartin349
My dryer will not automatically shut off when in the sensor mode. What do you think the problem is?
#2 Posted : Monday, January 2, 2012 3:29:40 AM(UTC)
Replacement parts for MAYTAG MDET446AYW DRYER- ELE | AppliancePartsPros.com
Check/clean your moisture sensor.
The machine may think that the clothes are still wet.
The way it works is that a voltage is applied to the 2 metal strips.
When moisture or dirt/residue is between the strips a current flows and the board senses this and continues to run.
Clean between the strips with a damp cloth and dry.
If this does not work try isopropyl alcohol, just be sure to let the vapors dissipate before trying it.
Kenmore dryer problems after replace drum belt/idler pulley (Dryer Repair)
by Hspot 11/22/2020 12:41:02 PM(UTC)
Cabrio dryer problems (Dryer Repair)
by artsalena 1/19/2017 2:37:30 PM(UTC)
GE dryer problems (Dryer Repair)
by js072384 5/12/2012 9:15:49 PM(UTC)
by Mickey_951 10/1/2011 5:53:04 PM(UTC)
Dryer Problems (Dryer Repair)
by Tsailor 3/4/2011 3:51:27 PM(UTC)
Dryer problems (Dryer Repair)
by Shoopes 11/16/2009 5:24:35 PM(UTC)
by talbot 11/2/2009 9:37:55 AM(UTC)
Asko condenser dryer problems (Dryer Repair)
by Marv Sumner 10/19/2009 11:05:38 AM(UTC)
Dryer problems mikeo (Dryer Repair)
by mikeo1899 8/4/2009 9:15:16 AM(UTC)
by berniefl 7/24/2009 6:13:21 AM(UTC)
Dryer problems HELP (Dryer Repair)
by MizzJessica 7/6/2009 10:39:42 PM(UTC)
by mbgrdido 3/24/2009 7:52:23 PM(UTC)
by janezucker 12/29/2008 9:36:33 AM(UTC)
Roper Dryer problems (Dryer Repair)
by b0001744 8/29/2008 9:38:02 AM(UTC)
by Myles.Smith 8/28/2008 6:06:48 PM(UTC)
