My dryer won't heat any more but still is able to tumble.Is there an process of elimination I need to follow to troubleshoot or is there an easy answer.
Does this help. The second picture the other was for someone else, sorry. libertyappl attached the following image(s):
there is the motor pulley and a clip that the belt rides on I think. I might have the answer with this diagram.
The belt only goes around the drum and the pulley there shouldn't be a clip it goes in Nat
