steve2016
#1 Posted : Thursday, April 21, 2016 8:12:47 AM(UTC)
steve2016
i'm testing & have water in it, do i need cloth to start ? i just hear buzz. top loaded machine, tried to reset by open & close lid 6 times. no go. i see a small hole on the far right side under the lid. is this where the reset switch was supposed to be. there's no magnet anywhere visible. it's possible that info. & reset was removed by used wash machine dealer. i'm guessing this is a 77 model from seeing it on youtube.:rolleyes:
Appliance Medics
#2 Posted : Thursday, April 21, 2016 11:47:43 AM(UTC)
Appliance Medics
First check to make sure your cold water valve is not clogged this can be done by shutting the water off to the machine and removing your cold water hose. If the inside of the valve the hose attaches to is clogged up with dirt you may need to clean it out. If still having trouble let me know
110.24622300 direct drive washer wont agitate or spin motor hums (Washer Repair)
by Guest 10/10/2021 7:32:00 PM(UTC)
my washer wont agitate or spin ULTIMATE CARE ll (Washer Repair)
by ballprez6 12/26/2014 11:12:12 AM(UTC)
GE Profile washer wont agitate or spin, motor will hum (Washer Repair)
by copperman 8/12/2014 4:20:30 PM(UTC)
washer wont agitate or spin (Washer Repair)
by bjsmith7 3/9/2014 7:19:34 PM(UTC)
roper washer wont agitate or spin!!!! (Washer Repair)
by mrbreezio 4/28/2012 12:24:29 AM(UTC)
Kenmore front load washer wont agitate or spin (Washer Repair)
by ebcravens 1/10/2012 2:27:09 PM(UTC)
hotpoint washer wont agitate or spin (Washer Repair)
by bksmith623 10/8/2011 9:14:31 AM(UTC)
GE Washer wont agitate or spin (Washer Repair)
by tinkerbell63 10/4/2011 3:21:59 AM(UTC)
by lpadilla 6/19/2011 10:06:42 AM(UTC)
by mikeyk01 4/19/2011 6:58:18 AM(UTC)
by Chukcharp 1/31/2011 8:57:01 PM(UTC)
Ge Washer Wont Agitate Or Spin (Washer Repair)
by cameo591 11/19/2010 3:31:06 PM(UTC)
washer wont agitate or spin, makes grinding noise (Washer Repair)
by donnascruggs 10/3/2009 9:02:12 AM(UTC)
by jamc0616 9/3/2009 6:03:30 PM(UTC)
washer wont agitate or spin out just hums (Washer Repair)
by bobcat1206 7/9/2009 8:53:21 AM(UTC)
