i'm testing & have water in it, do i need cloth to start ? i just hear buzz. top loaded machine, tried to reset by open & close lid 6 times. no go. i see a small hole on the far right side under the lid. is this where the reset switch was supposed to be. there's no magnet anywhere visible. it's possible that info. & reset was removed by used wash machine dealer. i'm guessing this is a 77 model from seeing it on youtube.:rolleyes:
First check to make sure your cold water valve is not clogged this can be done by shutting the water off to the machine and removing your cold water hose. If the inside of the valve the hose attaches to is clogged up with dirt you may need to clean it out. If still having trouble let me know
