jeanmoore
#1 Posted : Wednesday, December 9, 2015 9:33:47 AM(UTC)
jeanmoore
When our freezer goes into defrost mode it kicks the breaker. It will run about 10 hours and then it will kick the breaker.
#2 Posted : Wednesday, December 9, 2015 1:14:59 PM(UTC)
Parts for Whirlpool ED5SHAXML10 Refrigerator - AppliancePartsPros.com
Try forcing a defrost cycle to confirm that it is the defrost that is tripping the breaker.
If yes unplug the unit and check:
P7 to P4 at the defrost board should be in the 20 to 30 ohms.
Also check from P7 wire to a ground point on the unit. The wire should be disconnected from the board. If 0 ohms there is probably a short to the evaporator coils in the defrost thermostat.
The defrost thermostat must be frozen for this to work as it opens just above freezing.
Jenn Air - 30" slide in Range Kicks Breaker when oven turned on (Oven Repair (including Ranges and Cooktops))
by Jecody 8/3/2012 5:30:06 AM(UTC)
oven kicks breaker after about 1 hr (Oven Repair (including Ranges and Cooktops))
by wesnan 9/1/2009 6:52:23 PM(UTC)
