breezer4
#1 Posted : Wednesday, November 20, 2013 12:10:19 PM(UTC)
breezer4
My GE Spacemaker XL1800 runs constantly when plugged in. Turntable does not revolve, unit does not heat but inside light is on. Surface light operates by control panel as does the clock setting button but nothing else. Any of the buttons on the control panel make a funny noise when depressed.
Appliance Ninja
#2 Posted : Wednesday, November 20, 2013 12:12:30 PM(UTC)
Appliance Ninja
You likely have a faulty door switch. Do you have a meter to test continuity with?
breezer4
#3 Posted : Wednesday, November 20, 2013 12:56:28 PM(UTC)
breezer4
Ninja, Thank you for your immediate reply.
I just replaced the upper and lower door switches this morning. The 3rd (middle) switch has not been touched. I did notice that if I raise the door when it is in the closed position (unit is running) that it does stop running but the light remains on, control panel is blank and still makes funky noise when any button on the control panel is depressed. Not sure that any of this explains why the unit will not heat.
Appliance Ninja
#4 Posted : Wednesday, November 20, 2013 1:22:13 PM(UTC)
Appliance Ninja
If the control panel beeps and the display is blank, the control is faulty. What was the original reason you replaced the switches?
breezer4
#5 Posted : Wednesday, November 20, 2013 1:42:27 PM(UTC)
breezer4
Per your suggestion last week. I don't mind the expense of those as I never stated anything about what the control panel was doing.
Appliance Ninja
#6 Posted : Wednesday, November 20, 2013 1:48:40 PM(UTC)
Appliance Ninja
I am really sorry, I did not recognize your post but found the original one from the 13th. Without the control board issue, the door switches would have likely remedied the issue. However, if the panel beeps, we know it has power to it. So, if the display is out, we know the board is faulty. If you are interested, the part is below but will likely not be economical to replace.
GE WB27X10437 Pcb Ass'y - AppliancePartsPros.com
breezer4
#7 Posted : Wednesday, November 20, 2013 1:55:05 PM(UTC)
breezer4
I was afraid of the cost of a control board but will look into it. Thanks for all your help. I may be on my way to a 'new' purchase in a few days.
Appliance Ninja
#8 Posted : Wednesday, November 20, 2013 2:01:47 PM(UTC)
Appliance Ninja
I understand, thank you!
Microwave fuse blows out frequently (Microwave Repair)
by Guest 6/15/2024 4:55:42 AM(UTC)
LG LMV1680ST Microwave Door Switches (Microwave Repair)
by ctalbert150 6/13/2024 7:19:37 AM(UTC)
Whirlpool Oven/Microwave combo E1 F2 (Oven Repair (including Ranges and Cooktops))
Belarus MalcolmR 6/12/2024 10:02:00 AM(UTC)
Solved: Removing microwave unit from wall mounted Oven/Microwave combo (Oven Repair (including Ranges and Cooktops))
by MalikR 6/10/2024 3:04:18 PM(UTC)
Whirlpool Gold Accubake Oven/Microwave (Oven Repair (including Ranges and Cooktops))
by Guest 6/10/2024 10:21:28 AM(UTC)
How to pull microwave out of mw/oven combo (Oven Repair (including Ranges and Cooktops))
by cromking 5/6/2024 1:13:05 PM(UTC)
Microwave goes dead when hot (Microwave Repair)
by Guest 5/5/2024 8:05:15 AM(UTC)
Door Switch Help With Samsung Microwave Model ME21M706BAS (Microwave Repair)
by clagrow 5/2/2024 6:28:45 AM(UTC)
GE PT7800SHASS Combination Microwave / Oven - Key Panel SHORTED (Oven Repair (including Ranges and Cooktops))
by RCAppl 4/23/2024 7:59:18 AM(UTC)
GE Oven - Microwave/Oven PT7800SH2SSA (Oven Repair (including Ranges and Cooktops))
by Guest 2/13/2024 11:22:12 AM(UTC)
Kenmore Pizza Oven Microwave (Microwave Repair)
by mwjkmail 2/3/2024 5:10:49 PM(UTC)
Kitchenaid (Whirlpool) Microwave door switches (Microwave Repair)
by ForumUser1 1/11/2024 1:11:07 PM(UTC)
Whirlpool Microwave Lower Bulb will not turn on (WMH31017HS08) (Microwave Repair)
by Axtell 1/2/2024 3:49:44 PM(UTC)
Kitchen aid electric wall microwave and oven (Microwave Repair)
by Guest 11/9/2023 8:15:09 AM(UTC)
Frigidaire Microwave PLMVZ169HCA (Microwave Repair)
by Guest 10/25/2023 11:02:01 AM(UTC)
