2 Pages12>
Ruey
#1 Posted : Monday, November 18, 2013 7:02:06 AM(UTC)
Ruey
Freezer will not cool. High temperature light on the door panel stays on.
Appliance Ninja
#2 Posted : Monday, November 18, 2013 7:13:49 AM(UTC)
Appliance Ninja
Can you hear the compressor running or tell if it is hot or cold to the touch?
Ruey
#3 Posted : Monday, November 18, 2013 8:45:41 AM(UTC)
Ruey
Appliance Ninja, The compressor is warm to the touch and I'm not sure if it is running.
Appliance Ninja
#4 Posted : Monday, November 18, 2013 8:50:06 AM(UTC)
Appliance Ninja
Is the panel at the back on the bottom, inside the freezer cold? Can you hear a fan running inside the freezer?
Ruey
#5 Posted : Monday, November 18, 2013 9:04:13 AM(UTC)
Ruey
Appliance Ninja, The fan is running but the panel is not cold.
Appliance Ninja
#6 Posted : Monday, November 18, 2013 9:10:29 AM(UTC)
Appliance Ninja
Okay, so if the fan is running, the compressor should be running. Can you feel it vibrate at all? On the side of the compressor is an electrical component that starts the compressor. If the compressor is warm but not vibrating, that part may be faulty. Can you tell if the compressor is vibrating at all?
Ruey
#7 Posted : Monday, November 18, 2013 10:18:56 AM(UTC)
Ruey
Appliance Ninja
Tha compresor is warm but not vibrating.
Appliance Ninja
#8 Posted : Monday, November 18, 2013 10:25:18 AM(UTC)
Appliance Ninja
Okay, so if you unplug the freezer and remove the electrical box on the side of the compressor (it will pull off) and shake it, does it rattle?
Ruey
#9 Posted : Monday, November 18, 2013 10:40:11 AM(UTC)
Ruey
Appliance Ninga
I removed the box, it does not rattle
Appliance Ninja
#10 Posted : Monday, November 18, 2013 10:42:38 AM(UTC)
Appliance Ninja
Okay, that is not good. Since the compressor is warm, we know it is getting power. Since it is not running, the compressor may be bad or that starter may be bad. Usually, when they fail, they will rattle, but not always. Do you have a meter to test resistance with?
LG Fridge - Air condensing at back of freezer (Refrigerator & Freezer Repair)
by Guest 6/25/2024 5:44:16 AM(UTC)
GE refrigerator/freezer side by side (Refrigerator & Freezer Repair)
by Pdynamo 6/20/2024 6:20:43 PM(UTC)
Kitchenaid refrigerator and freezer intermittently to warm (Refrigerator & Freezer Repair)
by Guest 6/18/2024 12:12:20 PM(UTC)
Mysterious leak -Top Freezer w/Ice maker (Refrigerator & Freezer Repair)
by St.B 6/18/2024 8:40:52 AM(UTC)
GE bottom freezer model #: PFE28KBLTS not cooling well and no ice (Refrigerator & Freezer Repair)
by Danny1976 6/7/2024 12:43:43 PM(UTC)
GE bottom freezer not cooling well and no ice (Refrigerator & Freezer Repair)
by Guest 6/7/2024 7:31:51 AM(UTC)
Ice block in freezer (Refrigerator & Freezer Repair)
by bassbuddy25 6/5/2024 12:10:09 PM(UTC)
Freezer is cooling ok- top shelves in fridge ok, lower shelves in fridge too warm (Refrigerator & Freezer Repair)
by Guest 6/5/2024 11:24:33 AM(UTC)
Kenmore 106.74203402 fridge/freezer not cooling (Refrigerator & Freezer Repair)
by ryancg 5/26/2024 7:58:26 PM(UTC)
Refrigerator freezer (freezer is above refigerator,) (Refrigerator & Freezer Repair)
by cwillman 5/16/2024 12:29:58 PM(UTC)
Freezer Help from Whirlpool Unit (Refrigerator & Freezer Repair)
by Guest 5/15/2024 5:37:40 AM(UTC)
Water Dribbing into Freezer (Refrigerator & Freezer Repair)
by mbc320 5/14/2024 3:39:48 PM(UTC)
KitchenAid freezer gasket needed (Refrigerator & Freezer Repair)
by Kris Ballew 4/30/2024 6:27:57 PM(UTC)
Samsung Rs261MDWP Freezer Evap fan (Refrigerator & Freezer Repair)
by Jben04 4/29/2024 12:37:29 PM(UTC)
Electrolux fridge compartment not cooling, freezer is cold (Refrigerator & Freezer Repair)
by Minthook 4/22/2024 8:17:01 AM(UTC)
2 Pages12>
