joey_boomboom
#1 Posted : Wednesday, February 13, 2013 11:54:54 AM(UTC)
joey_boomboom
I have a frigidaire over the range microwave that does not start. If you pull up on the door it'll start up but then the timer will not work and it doesn't heat. If I just leave it alone and hit start the timer will go but nothing will happen. Is it cheaper just to buy a new one or is there a fix?
Simon / APP Team
#2 Posted : Wednesday, February 13, 2013 12:07:35 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Unplug the unit.
If you'll remove the top grill and control panel you should be able to get to the door switches. Check the switches performance with open and closed door, check the wire contacts.
Here are the breakdown diagram and Oven / Cabinet parts for Frigidaire FMV156DCC - AppliancePartsPros.com
Post the results.
Simon.
joey_boomboom
#3 Posted : Wednesday, February 13, 2013 12:26:06 PM(UTC)
joey_boomboom
Thanks for the quick reply. How do I check the connections?
Simon / APP Team
#4 Posted : Wednesday, February 13, 2013 1:32:12 PM(UTC)
Simon / APP Team
Groups: APP Team
Look for discoloration and melted insulation.
Simon.
joey_boomboom
#5 Posted : Wednesday, February 13, 2013 2:52:12 PM(UTC)
joey_boomboom
I opened it up and everything looks normal on the connections I can see. I looked at what happens when I lift the door but still nothing looked out of place.
Simon / APP Team
#6 Posted : Wednesday, February 13, 2013 3:31:14 PM(UTC)
Simon / APP Team
Groups: APP Team
You need to check the door switches with the multimeter for continuity.
Remove the wires first and then C to NO no continuity with the door open, C to NO continuity with the door closed.
Opposite reading for the C to NC contacts.
Simon.
Frigidaire problems (replaced control box kit) (Refrigerator & Freezer Repair)
by mcjunk 9/27/2011 10:10:27 AM(UTC)
Frigidaire problems (Dishwasher Repair)
by spooner8 10/31/2010 4:06:03 PM(UTC)
Frigidaire Problems (diganosis help please) (Dishwasher Repair)
by mattlach 8/31/2010 10:57:32 AM(UTC)
Frigidaire problem (Refrigerator & Freezer Repair)
by jlink 5/24/2008 10:07:06 AM(UTC)
