joey_boomboom
#1 Posted : 12 years ago
joey_boomboom
I have a frigidaire over the range microwave that does not start. If you pull up on the door it'll start up but then the timer will not work and it doesn't heat. If I just leave it alone and hit start the timer will go but nothing will happen. Is it cheaper just to buy a new one or is there a fix?
Simon / APP Team
#2 Posted : 12 years ago
Simon / APP Team
Groups: APP Team
Hi.
Unplug the unit.
If you'll remove the top grill and control panel you should be able to get to the door switches. Check the switches performance with open and closed door, check the wire contacts.
Here are the breakdown diagram and Oven / Cabinet parts for Frigidaire FMV156DCC - AppliancePartsPros.com
Post the results.
Simon.
joey_boomboom
#3 Posted : 12 years ago
joey_boomboom
Thanks for the quick reply. How do I check the connections?
Simon / APP Team
#4 Posted : 12 years ago
Simon / APP Team
Groups: APP Team
Look for discoloration and melted insulation.
Simon.
joey_boomboom
#5 Posted : 12 years ago
joey_boomboom
I opened it up and everything looks normal on the connections I can see. I looked at what happens when I lift the door but still nothing looked out of place.
Simon / APP Team
#6 Posted : 12 years ago
Simon / APP Team
Groups: APP Team
You need to check the door switches with the multimeter for continuity.
Remove the wires first and then C to NO no continuity with the door open, C to NO continuity with the door closed.
Opposite reading for the C to NC contacts.
Simon.
Frigidaire problems (replaced control box kit) (Refrigerator & Freezer Repair)
by mcjunk 13 years ago
Frigidaire problems (Dishwasher Repair)
by spooner8 14 years ago
Frigidaire Problems (diganosis help please) (Dishwasher Repair)
by mattlach 15 years ago
Frigidaire problem (Refrigerator & Freezer Repair)
by jlink 17 years ago
