I replaced the ice maker for my amana fridge because the old ice maker appeared to be leaking water into the ice bucket making one large clump of ice. This unit is doing the same thing, I turned the small water supply screw down but that did not help. I don't believe the ice maker is bad because I was watching the water going into the fill cup of the ice maker out of the feed line and it was splashing all over, could this be one of the feed/water valves. I just replaced the water valve and I am getting the same problem, The water from the feed tube is being forced into the cup causing it to splash all into the ice bucket any suggestions?
Groups: APP Team
Hi.
Try to adjust the fill tube (the distance between it and the fill cup).Make sure it's not touching the cup.
Simon.
I put a 90 degree 1/2" pvc elbow on the end of the feed tube, This seems to have fixed my problem. The elbow directs the water down into the ice maker without splashing into the ice bucket creating one giant block of ice! Very easy and inexpensive fix.
Groups: APP Team
Hi.
Nice solution and inexpensive too.
Simon.
Thanks for all your help.
Groups: APP Team
Robert Shaw Fireplace Gas Valve - Sticks
(Heating, Ventilation, and Air Conditioning (HVAC))
by Guest
11/15/2023 4:04:14 PM(UTC)
can I replace my DCS igniter (211541) with Robert Shaw replacement?
(Oven Repair (including Ranges and Cooktops))
by joeb2
2/24/2019 4:16:29 AM(UTC)
robert mikolay
(Refrigerator & Freezer Repair)
by Robert Mikolay
10/31/2016 10:31:50 AM(UTC)
need wiring diagram for magic chef furnace and ac unit with robertshaw gas valve and
by bigdaddy88
8/2/2012 4:16:30 PM(UTC)
Robert
(Washer Repair)
by DALRO
5/1/2012 2:33:49 PM(UTC)
robert
by RobertR70
4/6/2012 4:40:10 PM(UTC)
Robert R.
(Washer Repair)
by Robert R.
5/14/2011 3:47:52 PM(UTC)
robertshaw defective gas valve?
by lrg47
1/31/2010 10:10:08 AM(UTC)
Robertshaw gas valve
by feded
10/12/2009 8:56:43 PM(UTC)
OLD Modern Maid Robert Shaw Oven
by Hodgi
9/23/2009 2:35:58 PM(UTC)
10 yr old robert shaw gas valve installing new one
(General Talk)
by jess.good@live.com
12/9/2008 3:26:59 PM(UTC)
Robertshaw gas valve question (bad regulator?)
by Fong
6/10/2008 7:25:20 AM(UTC)
Old Robert Shaw thermostat connections
by jkosanke
5/1/2008 8:19:16 AM(UTC)
robert
by rmitche2@stx.rr.com
2/4/2008 7:50:49 AM(UTC)
