rawhitman1@aol.com
#1 Posted : Tuesday, February 12, 2013 4:15:26 PM(UTC)
rawhitman1@aol.com
I replaced the ice maker for my amana fridge because the old ice maker appeared to be leaking water into the ice bucket making one large clump of ice. This unit is doing the same thing, I turned the small water supply screw down but that did not help. I don't believe the ice maker is bad because I was watching the water going into the fill cup of the ice maker out of the feed line and it was splashing all over, could this be one of the feed/water valves. I just replaced the water valve and I am getting the same problem, The water from the feed tube is being forced into the cup causing it to splash all into the ice bucket any suggestions?
Simon / APP Team
#2 Posted : Wednesday, February 13, 2013 2:08:31 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Try to adjust the fill tube (the distance between it and the fill cup).Make sure it's not touching the cup.
Simon.
rawhitman1@aol.com
#3 Posted : Friday, February 15, 2013 6:28:44 AM(UTC)
rawhitman1@aol.com
I put a 90 degree 1/2" pvc elbow on the end of the feed tube, This seems to have fixed my problem. The elbow directs the water down into the ice maker without splashing into the ice bucket creating one giant block of ice! Very easy and inexpensive fix.
Simon / APP Team
#4 Posted : Friday, February 15, 2013 9:05:08 AM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Nice solution and inexpensive too.
Simon.
rawhitman1@aol.com
#5 Posted : Friday, February 15, 2013 10:52:08 AM(UTC)
rawhitman1@aol.com
Thanks for all your help.
Simon / APP Team
#6 Posted : Friday, February 15, 2013 11:01:18 AM(UTC)
Simon / APP Team
Groups: APP Team
It's my pleasure.
Simon.
Robert Shaw Fireplace Gas Valve - Sticks (Heating, Ventilation, and Air Conditioning (HVAC))
by Guest 11/15/2023 4:04:14 PM(UTC)
can I replace my DCS igniter (211541) with Robert Shaw replacement? (Oven Repair (including Ranges and Cooktops))
by joeb2 2/24/2019 4:16:29 AM(UTC)
robert mikolay (Refrigerator & Freezer Repair)
by Robert Mikolay 10/31/2016 10:31:50 AM(UTC)
need wiring diagram for magic chef furnace and ac unit with robertshaw gas valve and (Heating, Ventilation, and Air Conditioning (HVAC))
by bigdaddy88 8/2/2012 4:16:30 PM(UTC)
Robert (Washer Repair)
by DALRO 5/1/2012 2:33:49 PM(UTC)
robert (Refrigerator & Freezer Repair)
by RobertR70 4/6/2012 4:40:10 PM(UTC)
Robert R. (Washer Repair)
by Robert R. 5/14/2011 3:47:52 PM(UTC)
robertshaw defective gas valve? (Heating, Ventilation, and Air Conditioning (HVAC))
by lrg47 1/31/2010 10:10:08 AM(UTC)
Robertshaw gas valve (Heating, Ventilation, and Air Conditioning (HVAC))
by feded 10/12/2009 8:56:43 PM(UTC)
OLD Modern Maid Robert Shaw Oven (Oven Repair (including Ranges and Cooktops))
by Hodgi 9/23/2009 2:35:58 PM(UTC)
10 yr old robert shaw gas valve installing new one (General Talk)
by jess.good@live.com 12/9/2008 3:26:59 PM(UTC)
Robertshaw gas valve question (bad regulator?) (Heating, Ventilation, and Air Conditioning (HVAC))
by Fong 6/10/2008 7:25:20 AM(UTC)
Old Robert Shaw thermostat connections (Oven Repair (including Ranges and Cooktops))
by jkosanke 5/1/2008 8:19:16 AM(UTC)
robert (Oven Repair (including Ranges and Cooktops))
by rmitche2@stx.rr.com 2/4/2008 7:50:49 AM(UTC)
