I have a Whirlpool Duet washer, 2 years old. My problem is it starts, fills up with water then stops and the light next to the washer button flashes on and off and it keeps beeping...won't wash only will rinse and drain. Can anyone help?
Underneath the top are some tech notes that will show you how to put it into a diagnostic mode and generate error codes.
See if you can get some insight from that, and use the notes to check out the control unit, that sounds like your problem.
