michellejacobson@email.co
#1 Posted : Monday, December 12, 2011 10:10:22 AM(UTC)
I noticed a gas leak coming from the on off nobs on my stove. I had the gas company in and they turned off the supply to the stove. They checked all the valves but no gas was leaking from any of them. We even lifted the cooktop up off the countertop to check the seal on the gas connection to the appliance. I was wondering if anyone had any suggestions on what could be going on and why the gas is leaking through the on off nobs. I have been online to try and figure out what could be happening but am not able to figure out what happens in the area below the nobs as it is enclosed. I would appreciate advice on what to do.
ApplianceJunk
#2 Posted : Monday, December 12, 2011 11:55:48 AM(UTC)
ApplianceJunk
Hi,
What did the gas company suggest doing?
Did they turn the gas back on?
gas leaking from burners and oven cavity (Oven Repair (including Ranges and Cooktops))
by MarisaCKD 6/2/2020 6:45:23 AM(UTC)
Roper/Whirlpool dryer gas leak (Dryer Repair)
by STLDIYer 7/20/2017 12:47:35 PM(UTC)
Gas Leak AFTER on for 15 minuets (Oven Repair (including Ranges and Cooktops))
by therealfleen 1/16/2015 9:48:47 AM(UTC)
Gas leak smell from oven (Oven Repair (including Ranges and Cooktops))
by Aguilareagle1 11/16/2013 11:46:06 AM(UTC)
Gas leaking when oven is shut off (Oven Repair (including Ranges and Cooktops))
by charlieq3 3/24/2011 10:04:10 AM(UTC)
gas leaks from base of burner (Oven Repair (including Ranges and Cooktops))
Belarus Cyprien 6/24/2010 8:59:36 AM(UTC)
My oven wont ignite after I tightened gas leaking connector (Oven Repair (including Ranges and Cooktops))
by raminla 6/2/2010 12:14:35 PM(UTC)
gas leak from valve when dryer is off (Dryer Repair)
by drainpros 4/19/2010 8:14:56 AM(UTC)
Gas leak (Oven Repair (including Ranges and Cooktops))
by paris795 11/23/2009 8:41:56 AM(UTC)
small gas leak/smell of gas (Oven Repair (including Ranges and Cooktops))
by jmarc 10/7/2009 12:10:44 PM(UTC)
Kenmore gas stove W/ gas leak (Oven Repair (including Ranges and Cooktops))
by Snake 7/22/2009 12:50:33 AM(UTC)
Magic Chef 3468xva gas leak (Oven Repair (including Ranges and Cooktops))
by indianfan79 6/30/2009 12:05:07 PM(UTC)
gas leaking oven (Oven Repair (including Ranges and Cooktops))
by steinle 6/29/2009 8:30:26 AM(UTC)
gas leaking after installing new glow igniter (Oven Repair (including Ranges and Cooktops))
by schimickn 6/27/2009 5:56:54 AM(UTC)
by cesar0878 6/18/2009 6:53:10 PM(UTC)
