michellejacobson@email.co
#1 Posted : 13 years ago
I noticed a gas leak coming from the on off nobs on my stove. I had the gas company in and they turned off the supply to the stove. They checked all the valves but no gas was leaking from any of them. We even lifted the cooktop up off the countertop to check the seal on the gas connection to the appliance. I was wondering if anyone had any suggestions on what could be going on and why the gas is leaking through the on off nobs. I have been online to try and figure out what could be happening but am not able to figure out what happens in the area below the nobs as it is enclosed. I would appreciate advice on what to do.
ApplianceJunk
#2 Posted : 13 years ago
ApplianceJunk
Hi,
What did the gas company suggest doing?
Did they turn the gas back on?
gas leaking from burners and oven cavity (Oven Repair (including Ranges and Cooktops))
by MarisaCKD 5 years ago
Roper/Whirlpool dryer gas leak (Dryer Repair)
by STLDIYer 8 years ago
Gas Leak AFTER on for 15 minuets (Oven Repair (including Ranges and Cooktops))
by therealfleen 10 years ago
Gas leak smell from oven (Oven Repair (including Ranges and Cooktops))
by Aguilareagle1 11 years ago
Gas leaking when oven is shut off (Oven Repair (including Ranges and Cooktops))
by charlieq3 14 years ago
gas leaks from base of burner (Oven Repair (including Ranges and Cooktops))
by Cyprien 15 years ago
My oven wont ignite after I tightened gas leaking connector (Oven Repair (including Ranges and Cooktops))
by raminla 15 years ago
gas leak from valve when dryer is off (Dryer Repair)
by drainpros 15 years ago
Gas leak (Oven Repair (including Ranges and Cooktops))
by paris795 15 years ago
small gas leak/smell of gas (Oven Repair (including Ranges and Cooktops))
by jmarc 15 years ago
Kenmore gas stove W/ gas leak (Oven Repair (including Ranges and Cooktops))
by Snake 16 years ago
Magic Chef 3468xva gas leak (Oven Repair (including Ranges and Cooktops))
by indianfan79 16 years ago
gas leaking oven (Oven Repair (including Ranges and Cooktops))
by steinle 16 years ago
gas leaking after installing new glow igniter (Oven Repair (including Ranges and Cooktops))
by schimickn 16 years ago
by cesar0878 16 years ago
