I just purchased a new water inlet valve, it is a three solenoid valve and the new part appears to have quick connect type water line fittings ( or something) on 3 of the outlets and 2 of the outlets use the threaded type water line connections on the new part ,, my old inlet valve uses threaded connections on all the water lines on the valve, the valve looks the same except for how the water lines connect to the new valve , do I have a wrong part ? how do I connect the lines ? or should I send it back for a return , it's useless the way it is out of the box since my frige uses all threaded type water line connections ..... any help or info would be much appreciated .................. thanks
Originally Posted by: ApplianceJunk ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Thanks appliancejunk for the reply and the video link and yep the inlet valves have switched to quick connect fittings,the one that was sent was missing some of the quick connect inserts, Adam from this site is sending another unit (thanks Adam) and I'll see how it goes ...... take care
