green_eyed1
#1 Posted : Sunday, May 17, 2009 12:33:05 PM(UTC)
green_eyed1
The hook won't move to open or close. Won't heat unless door closed and it won't close or open unless it's forced by hooking the hook and moving by hand.:confused: Is it an easy fix?
#2 Posted : Sunday, May 17, 2009 3:07:49 PM(UTC)
Did it show any failure code? If you are not sure then push and hold the "Off/Cancel" button for 5 seconds to recall the last failure code. Post the results.
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL GY398LXPB00 | AppliancePartsPros.com
green_eyed1
#3 Posted : Sunday, May 17, 2009 5:29:49 PM(UTC)
green_eyed1
It said EO F2
green_eyed1
#4 Posted : Sunday, May 17, 2009 5:32:08 PM(UTC)
green_eyed1
It said EO F2 code. This is an oven, not microwave.
#5 Posted : Sunday, May 17, 2009 5:42:02 PM(UTC)
Most likely the problem is a bad door latch (#22 on the diagram).
- The part number for the door latch assembly is AP3874017
green_eyed1
#6 Posted : Sunday, May 17, 2009 5:54:11 PM(UTC)
green_eyed1
I know this, but is there an adjustment on it and how do you replace it?
#7 Posted : Sunday, May 17, 2009 6:01:04 PM(UTC)
This part is not adjustable and/or repairable. You have to lift up the top panel. You can find the instructions in the Service manual.
green_eyed1
#8 Posted : Sunday, May 17, 2009 8:13:18 PM(UTC)
green_eyed1
Thank you so much. Your advice is right on. I wll try to do it. I think I can. If not I will call a repair person.
#9 Posted : Sunday, May 17, 2009 11:03:08 PM(UTC)
