The hook won't move to open or close. Won't heat unless door closed and it won't close or open unless it's forced by hooking the hook and moving by hand.:confused: Is it an easy fix?
Originally Posted by: Gene It said EO F2
It said EO F2 code. This is an oven, not microwave. Originally Posted by: Gene
Most likely the problem is a bad door latch (#22 on the diagram). - The part number for the door latch assembly is AP3874017Gene.
I know this, but is there an adjustment on it and how do you replace it? Originally Posted by: Gene Most likely the problem is a bad door latch (#22 on the diagram). - The part number for the door latch assembly is AP3874017Gene.
This part is not adjustable and/or repairable. You have to lift up the top panel. You can find the instructions in the Service manual. Gene.
Thank you so much. Your advice is right on. I wll try to do it. I think I can. If not I will call a repair person. Originally Posted by: Gene This part is not adjustable and/or repairable. You have to lift up the top panel. You can find the instructions in the Service manual. Gene.
