Keypad was getting erratic at times. Progressively got worse to where it now does not work. Everything else seems to function correctly if you can get in a command. Does it sound like a membrane pad is needed ?
Kim
Originally Posted by: kim bray ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Keypad was getting erratic at times. Progressively got worse to where it now does not work. Everything else seems to function correctly if you can get in a command. Does it sound like a membrane pad is needed ?
Kim Hi Kim. Yes, you will need to replace the keypad assy. Part number: AP3837496
