Originally Posted by: myamanastove Hi will somebody please send me the error codes for Amana Model No. AC5720AS?
Thanks! What exactly is wrong with your oven? The model number you posted does not come up. Verify and repost it. Gene.
Hi Gene:
Thanks for responding to my message. My Amana oven is showing F-1 code. Will you be able to send me the corresponding error to that code?
myamanaoven
Gene. Hi Gene: Excuse me if I reply on different pages. Still knew to this site. My Amana keeps on beeping every minute and shows F-1. Help! myamanastove
Have you verified the model number?
Yesterday, as my wife was cooking a spaghetti sauce in a large pot, the display of my Thermador CIT365DS/01 showed 2 fault codes. First E R4 2, then a few seconds later E R2 2. The fault code disapear as soon as I removed the pot from the induction burner, and came as soon as I put it back in place !
I tried to call Thermador this morning but was told that the explanation of the codes was reserved to technicians and that the cause might be the pot...
Any help would be greatly appreciated.
Make sure the pots you are using are:
1) Enameled steel pots and pans. 2) Cast iron pots and pans. 3) Special stainless steel utensils for induction cooking All of the following pans are not valid for induction cooking:
Non-ferromagnetic or non-metallic materials. Aluminum pots and pans. Copper pots and pans. Brass pots and pans. Standard stainless pots and pans. Glass (“Pyrex”) containers. Earthenware pans
Otherwise the error code "ErXY" means: "The touch control has an internal failure" and the repair has to be done by Thermador authorized service. Any parts as well as the diagrams are not available for public by Thermador.
I disconnected membrane panel from ERC and it gave me a new F7 code (membrane unhooked) I had F1-8 and F8-2 codes prior. All membrane switches accept commands but oven turns off after 10 sec and F8-2 displays. Originally Posted by: Admin / APP Team When your oven is flashing an error code, it usually means something specific, for example F3 usually stands for a faulty oven sensor. To help you identify what each code means, we have put together a list of oven error codes (or fault codes, as they're called). Once you know which component has failed, simply enter your appliance model number in our part search, find and order the part, and we'll take it from there. If it says that your part is in stock, you can expect to get it in just a few days, usually within 1-2 business days. F1 error code usually means that either the touch pad or the clock (ERC) is bad. It's simple if your model incorporates both as a single assembly - replace the clock/touch pad, problem's solved. But, when the touch pad is a separate component from the clock, how do you tell which of the two has failed, without having to replace both? Well, we have a simple test that can show you whether it's the clock (ERC) or the touch pad (membrane switch) that needs to be replaced. The test is available on the error code page right below the list of brands. If you have additional questions, please click on the "POST NEW TOPIC" button on the previous page to post your question.
Originally Posted by: ss195 I disconnected membrane panel from ERC and it gave me a new F7 code (membrane unhooked) I had F1-8 and F8-2 codes prior. All membrane switches accept commands but oven turns off after 10 sec and F8-2 displays. What is the complete model number of the oven? Gene.
You have been a member since:: 8/9/2009(UTC) Posts: 10
Can'tget Kenmore mod # to come up. 790.7748980 looking for code #F11
Originally Posted by: double bogey Can'tget Kenmore mod # to come up. 790.7748980 looking for code #F11 The model number you posted is incomplete. Verify and repost it. Gene.
