21 Pages«<1213141516>»
#131 Posted : Monday, November 30, 2009 8:05:55 PM(UTC)
Originally Posted by: myamanastove Go to Quoted Post
Hi will somebody please send me the error codes for Amana Model No. AC5720AS?
Thanks!
What exactly is wrong with your oven?
The model number you posted does not come up. Verify and repost it.
myamanastove
#132 Posted : Wednesday, December 2, 2009 8:04:13 AM(UTC)
myamanastove
Hi Gene:
Thanks for responding to my message. My Amana oven is showing F-1 code. Will you be able to send me the corresponding error to that code?
myamanaoven
myamanastove
#133 Posted : Wednesday, December 2, 2009 8:07:20 AM(UTC)
myamanastove
Hi Gene:
Excuse me if I reply on different pages. Still knew to this site.
My Amana keeps on beeping every minute and shows F-1. Help!
myamanastove
#134 Posted : Thursday, December 3, 2009 7:35:10 PM(UTC)
Have you verified the model number?
MonBonLupin
#135 Posted : Wednesday, March 3, 2010 7:58:42 AM(UTC)
MonBonLupin
Yesterday, as my wife was cooking a spaghetti sauce in a large pot, the display of my Thermador CIT365DS/01 showed 2 fault codes. First E R4 2, then a few seconds later E R2 2. The fault code disapear as soon as I removed the pot from the induction burner, and came as soon as I put it back in place !
I tried to call Thermador this morning but was told that the explanation of the codes was reserved to technicians and that the cause might be the pot...
Any help would be greatly appreciated.
#136 Posted : Wednesday, March 3, 2010 4:16:38 PM(UTC)
Make sure the pots you are using are:
1) Enameled steel pots and pans.
2) Cast iron pots and pans.
3) Special stainless steel utensils for induction cooking
All of the following pans are not valid for induction cooking:
Non-ferromagnetic or non-metallic materials.
Aluminum pots and pans.
Copper pots and pans.
Brass pots and pans.
Standard stainless pots and pans.
Glass (“Pyrex”) containers.
Earthenware pans
Otherwise the error code "ErXY" means: "
The touch control has an internal failure" and the repair has to be done by Thermador authorized service. Any parts as well as the diagrams are not available for public by Thermador.
ss195
#137 Posted : Sunday, March 14, 2010 1:08:50 PM(UTC)
ss195
I disconnected membrane panel from ERC and it gave me a new F7 code (membrane unhooked) I had F1-8 and F8-2 codes prior. All membrane switches accept commands but oven turns off after 10 sec and F8-2 displays.
Originally Posted by: Admin / APP Team Go to Quoted Post
When your oven is flashing an error code, it usually means something specific, for example F3 usually stands for a faulty oven sensor. To help you identify what each code means, we have put together a list of oven error codes (or fault codes, as they're called). Once you know which component has failed, simply enter your appliance model number in our part search, find and order the part, and we'll take it from there. If it says that your part is in stock, you can expect to get it in just a few days, usually within 1-2 business days.
F1 error code usually means that either the touch pad or the clock (ERC) is bad. It's simple if your model incorporates both as a single assembly - replace the clock/touch pad, problem's solved. But, when the touch pad is a separate component from the clock, how do you tell which of the two has failed, without having to replace both? Well, we have a simple test that can show you whether it's the clock (ERC) or the touch pad (membrane switch) that needs to be replaced. The test is available on the error code page right below the list of brands.
If you have additional questions, please click on the "POST NEW TOPIC" button on the previous page to post your question.
#138 Posted : Monday, March 15, 2010 1:24:59 PM(UTC)
What is the complete model number of the oven?
double bogey
#139 Posted : Thursday, April 29, 2010 7:30:12 AM(UTC)
double bogey
Can'tget Kenmore mod # to come up. 790.7748980
looking for code #F11
#140 Posted : Thursday, April 29, 2010 1:16:57 PM(UTC)
The model number you posted is incomplete. Verify and repost it.
Thermador Oven error codes (Oven Repair (including Ranges and Cooktops))
by jblake9000 9/25/2015 9:01:34 AM(UTC)
Oven Error Codes & Won't Heat Fully (Oven Repair (including Ranges and Cooktops))
by davem68 4/18/2013 7:46:23 AM(UTC)
Whirlpool oven error codes (Oven Repair (including Ranges and Cooktops))
by ajsml 9/10/2012 10:21:53 AM(UTC)
by fred jacoby 4/4/2012 9:44:17 AM(UTC)
by sigman 3/23/2012 9:08:14 AM(UTC)
kENMORE OVEN ERROR CODES E3 FI (Oven Repair (including Ranges and Cooktops))
by chrisb361 12/11/2011 3:37:20 PM(UTC)
Whirlpool Electic oven error codes (Oven Repair (including Ranges and Cooktops))
by fcarrelli 9/7/2010 5:56:53 AM(UTC)
Oven error codes F3 and F2 (Oven Repair (including Ranges and Cooktops))
by emidgette 6/1/2010 4:58:30 PM(UTC)
by emidgette 6/1/2010 4:56:50 PM(UTC)
GE Oven error codes (Oven Repair (including Ranges and Cooktops))
by BobChurch 9/1/2009 4:51:40 PM(UTC)
GE oven error codes (Oven Repair (including Ranges and Cooktops))
by bdeinhardt@aol.com 6/25/2009 5:47:37 AM(UTC)
Whirlpool Double Oven Error Codes (Oven Repair (including Ranges and Cooktops))
by alaucks 1/14/2009 9:31:27 AM(UTC)
by cndybkr 9/29/2008 12:13:03 PM(UTC)
Additional Oven Error Codes (Oven Repair (including Ranges and Cooktops))
by indydoug 11/15/2007 6:43:00 PM(UTC)
