ajsml
#1 Posted : 12 years ago
ajsml
My oven after a power failure shows codes EO FO and will not longer heat. What does this mean and is it a part that is easily replaced?
Simon / APP Team
#2 Posted : 12 years ago
Simon / APP Team
Groups: APP Team
Hi.
Please check the model number, the one you've posted not coming up.
Simon.
ajsml
#3 Posted : 12 years ago
ajsml
I'm sorry--it is RBS305PDQ8
Simon / APP Team
#4 Posted : 12 years ago
Simon / APP Team
Groups: APP Team
I don't believe there is F0 E0 code exists. Please double check it.
Simon.
ajsml
#5 Posted : 12 years ago
ajsml
Unless the bottom number is being cut off, that is what is showing--when the power came back on, it automatically turned on and the only way I could turn it off was at the breaker. So when I turned it back on a couple days later to cook, it turns on, but will not heat. Maybe it is an 8, but the number is cut in half???? I'll run check it again and see. Thank U!!
ajsml
#6 Posted : 12 years ago
ajsml
It says E0 on the left side and then in orange on the right side of the display, F0. Nothing is being cut off.
Simon / APP Team
#7 Posted : 12 years ago
Simon / APP Team
Groups: APP Team
Hi.
Also there is no code grater then F6.
Simon.
Simon / APP Team
#8 Posted : 12 years ago
Simon / APP Team
Groups: APP Team
Hi.
Most likely the control board should be replaced
Part number: 8186024
Here are the breakdown diagrams and Replacement parts for Whirlpool RBS305PDQ8 ELECTRIC OVEN | AppliancePartsPros.com
Simon.
PS. You can return any parts even if they been installed.
ajsml
#9 Posted : 12 years ago
ajsml
It says E0 on the left side of the display and F0 on the right side of the display in a differnt color.
