21 Pages«<1415161718>»
smitchell0269
#151 Posted : Monday, June 7, 2010 5:32:15 AM(UTC)
smitchell0269
The numbers you posted not even close to a valid error codes listed in the Tech sheet.
The first thing I would do is measure the voltage at the range wall outlet and at the control board. It suppose to be 240 VAC at the outlet and 120 VAC between P4-1 (white wire) and P4-3 (black wire). Make sure the black wire is hot and the white wire is neutral.
If the voltage reads OK, try to set the clock and use the Bake and Broil. Post the results.
Thanks Gene, I'll give that a try.
#152 Posted : Monday, June 7, 2010 11:34:46 AM(UTC)
Charles Hodges
#153 Posted : Saturday, November 20, 2010 6:50:44 AM(UTC)
Charles Hodges
thanks for your assistance
Originally Posted by: Admin / APP Team Go to Quoted Post
When your oven is flashing an error code, it usually means something specific, for example F3 usually stands for a faulty oven sensor. To help you identify what each code means, we have put together a list of oven error codes (or fault codes, as they're called). Once you know which component has failed, simply enter your appliance model number in our part search, find and order the part, and we'll take it from there. If it says that your part is in stock, you can expect to get it in just a few days, usually within 1-2 business days.
F1 error code usually means that either the touch pad or the clock (ERC) is bad. It's simple if your model incorporates both as a single assembly - replace the clock/touch pad, problem's solved. But, when the touch pad is a separate component from the clock, how do you tell which of the two has failed, without having to replace both? Well, we have a simple test that can show you whether it's the clock (ERC) or the touch pad (membrane switch) that needs to be replaced. The test is available on the error code page right below the list of brands.
If you have additional questions, please click on the "POST NEW TOPIC" button on the previous page to post your question.
eviejohn
#154 Posted : Wednesday, November 24, 2010 9:03:38 AM(UTC)
eviejohn
I have a whirlpool slide in stove with the accubake sstem about 5 years old. The control panel displays PF . I had a repair man look at it and said I need a new panel , $300 + some $ .He also said I can install one my self if I can find the part. Where can I find this part and is it called a control panel sensor?
#155 Posted : Wednesday, November 24, 2010 12:18:14 PM(UTC)
What is the complete model number of the range?
M.Kov17
#156 Posted : Monday, December 27, 2010 7:03:53 AM(UTC)
M.Kov17
Not sure if it's your control panel thats broken?
Try looking it up at
Fix Your Board dot Com / Techzone dot html
The guys at FIX YOUR BOARD repair oven contol boards--
Especially boards that are No Longer Available OR ARE ON BACK ORDER FOR MONTHS.
THEY PROVIDE A 2 YEAR WARRANTY THAT BACKS THEIR WORK AND THEY HAVE A TURN AROUND TIME OF LESS THAN A FEW DAYS!
Take a look at their website, or Give them a call at 5123551108 !
FIX YOUR BOARD DOT COM <<< without the spaces!
M.Kov17
#157 Posted : Monday, December 27, 2010 7:11:15 AM(UTC)
M.Kov17
google Fix Your Board
These guys repair oven control boards-- they back their work with a 2 year warranty, and have a quick turn around time .
Jefflaur1
#158 Posted : Friday, April 15, 2011 2:58:04 PM(UTC)
Jefflaur1
Pat,
Frigidaire has recently come out with new error codes, including F13. We'll update our code page shortly.
F13 stands for "Bad EEPROM Identification/Checksum error". If power cycling does not help, replace the electronic oven control. You can enter your oven model number here Appliance Parts search by model or part number | AppliancePartsPros.com and see price and availability for the control.
Hope this helps.
Is there a sheet that describes how to access that EOC? I have ordered the new part, but would like to know the steps to replace it. Email me direct if you like at: Jeff@jefflaurence.com
luapp
#159 Posted : Thursday, April 21, 2011 3:12:48 PM(UTC)
luapp
After a wasted service call, I replaced the control unit and two temperature probes. Each part replacement was very simple and seemed to fix the problem, but inevitably the code would reappear, sometimes in hours or days, sometimes in a couple months. Other than the error code, the oven and stove top worked fine, so we were unwilling to toss it out and buy a new one. So, in desperation, I simply moved the oven away from the wall about 1-1/2" to ensure that heat did not build up in the top of the stove where the controls are located. We have not had a single F1 error in more than 6 months. I am convinced that this is the source of the continuing problems we experienced and that any transient malfunctioning of the parts was due to heat buildup.
cdm1426
#160 Posted : Wednesday, August 24, 2011 8:53:23 AM(UTC)
cdm1426
Im getting an error code F20 on my control panel when I try to turn the oven on What could it be?
It's a frigidair range oven m# PLES389ECC
Thermador Oven error codes (Oven Repair (including Ranges and Cooktops))
by jblake9000 9/25/2015 9:01:34 AM(UTC)
Oven Error Codes & Won't Heat Fully (Oven Repair (including Ranges and Cooktops))
by davem68 4/18/2013 7:46:23 AM(UTC)
Whirlpool oven error codes (Oven Repair (including Ranges and Cooktops))
by ajsml 9/10/2012 10:21:53 AM(UTC)
by fred jacoby 4/4/2012 9:44:17 AM(UTC)
by sigman 3/23/2012 9:08:14 AM(UTC)
kENMORE OVEN ERROR CODES E3 FI (Oven Repair (including Ranges and Cooktops))
by chrisb361 12/11/2011 3:37:20 PM(UTC)
Whirlpool Electic oven error codes (Oven Repair (including Ranges and Cooktops))
by fcarrelli 9/7/2010 5:56:53 AM(UTC)
Oven error codes F3 and F2 (Oven Repair (including Ranges and Cooktops))
by emidgette 6/1/2010 4:58:30 PM(UTC)
by emidgette 6/1/2010 4:56:50 PM(UTC)
GE Oven error codes (Oven Repair (including Ranges and Cooktops))
by BobChurch 9/1/2009 4:51:40 PM(UTC)
GE oven error codes (Oven Repair (including Ranges and Cooktops))
by bdeinhardt@aol.com 6/25/2009 5:47:37 AM(UTC)
Whirlpool Double Oven Error Codes (Oven Repair (including Ranges and Cooktops))
by alaucks 1/14/2009 9:31:27 AM(UTC)
by cndybkr 9/29/2008 12:13:03 PM(UTC)
Additional Oven Error Codes (Oven Repair (including Ranges and Cooktops))
by indydoug 11/15/2007 6:43:00 PM(UTC)
