gloriacross
#1 Posted : Monday, August 8, 2011 11:57:10 AM(UTC)
gloriacross
Basekt Won't spin or Agitate. Nothing is jammed around the basket.
magician59
#2 Posted : Monday, August 8, 2011 7:07:58 PM(UTC)
magician59
First check the lid switch. If you can hear and feel a definite click when you depress the switch lever with a thin bladed screwdriver, it is probably good.
If you don't hear the motor running, check the timer. Check all the cycles. If it agitates and spins in other cycles, the timer is bad.
If you can hear the motor running, look for a broken motor coupling. This is the most common spin failure for this design,
Part number: AP3963893
If the motor coupling is intact, watch the clutch housing (just above the gearcase, which is directly behind the motor). It is a round housing, about an inch high, and 3 inches in diameter. If it is spinning, but the inner tub is not, the problem is likely a bad clutch. If it is not spinning, the trouble is most likely inside the gearcase.
Whirlpool won't spin (Washer Repair)
by kplumeriat 6/18/2014 1:10:48 PM(UTC)
Estate by Whirlpool Won't Spin, Just Buzzes (Washer Repair)
by Thundersloth 10/26/2013 10:17:30 AM(UTC)
Whirlpool won't spin with clothes, agitates fine... (Washer Repair)
by billsooner 3/4/2013 4:14:54 PM(UTC)
Whirlpool won't spin(knocking) (Washer Repair)
by cjenkins08 3/14/2012 3:59:43 PM(UTC)
Whirlpool won't spin on gentle knit cycle (Washer Repair)
by Bowdaddy 4/14/2011 8:17:21 AM(UTC)
Whirlpool Won't Spin (Washer Repair)
by hartzboys 2/10/2011 8:50:31 AM(UTC)
Whirlpool won't spin, oil on ground. (Washer Repair)
by cartero 4/22/2010 10:11:56 PM(UTC)
Belt drive Whirlpool won't spin (Washer Repair)
by brbartsc 11/26/2008 2:17:52 PM(UTC)
by BillMuggelberg 3/24/2008 8:32:20 AM(UTC)
by Satow 10/3/2007 2:16:41 PM(UTC)
