AppliancePartsPros.com
Appliance Repair Help
Washer Repair
Whirlpool won't spin with clothes, agitates fine...
Found my clothes sopping wet and a burning smell at end of washing cycle. Checked and found that it is still agitating, draining, and spinning (only when there is NO CLOTHING).
When I put it on spin cycle with clothes, you can hear the motor? trying to run, but nothing is happening (I am assuming where the burning smell is coming from). When I take the clothes out, and try spinning, it seems to get going fine.
I checked underneath and did not see any "rubber shavings" as I have seen on other a "coupling" problem.
PLEASE HELP! I am a teacher and am barely surviving month to month, I can't afford buying a new one or costly repairs.
Groups: APP Team
Hi. Check two things first. Remove the agitator and check if the drive block still has the grooves and engaging the spin tube. The drive block Part number: 389140
Washer Repair
