gloriacross
#1 Posted : 14 years ago
gloriacross
Basekt Won't spin or Agitate. Nothing is jammed around the basket.
magician59
#2 Posted : 14 years ago
magician59
First check the lid switch. If you can hear and feel a definite click when you depress the switch lever with a thin bladed screwdriver, it is probably good.
If you don't hear the motor running, check the timer. Check all the cycles. If it agitates and spins in other cycles, the timer is bad.
If you can hear the motor running, look for a broken motor coupling. This is the most common spin failure for this design,
Part number: AP3963893
If the motor coupling is intact, watch the clutch housing (just above the gearcase, which is directly behind the motor). It is a round housing, about an inch high, and 3 inches in diameter. If it is spinning, but the inner tub is not, the problem is likely a bad clutch. If it is not spinning, the trouble is most likely inside the gearcase.
Whirlpool won't spin (Washer Repair)
by kplumeriat 11 years ago
Estate by Whirlpool Won't Spin, Just Buzzes (Washer Repair)
by Thundersloth 11 years ago
Whirlpool won't spin with clothes, agitates fine... (Washer Repair)
by billsooner 12 years ago
Whirlpool won't spin(knocking) (Washer Repair)
by cjenkins08 13 years ago
Whirlpool won't spin on gentle knit cycle (Washer Repair)
by Bowdaddy 14 years ago
Whirlpool Won't Spin (Washer Repair)
by hartzboys 14 years ago
Whirlpool won't spin, oil on ground. (Washer Repair)
by cartero 15 years ago
Belt drive Whirlpool won't spin (Washer Repair)
by brbartsc 16 years ago
by BillMuggelberg 17 years ago
by Satow 17 years ago
