Replacement parts for WHIRLPOOL LEC5000PQ0 29" ELECTRIC DRYER | AppliancePartsPros.comSee the attachment for the wiring diagram.
[COLOR="DarkRed"]
Are there fuses beside the thermal fuse?[/COLOR]
Yes. There is a thermal cut off but it is located on the heater and will not effect the unit starting.
I am assuming then that you have checked the thermal fuse on the blower.
What about the door switch. Do they go out a lot?
This could be the problem. They do not go out a lot but that does not mean yours is OK.
First check that the switch is being activated when the door is closed.
Next unplug the unit and check the switch with a meter.
If OK, then check the push to start switch.
What specific things would just kill the power? Checked box out side fuses were fine.
Could also be the motor itself, the timer contacts BU/BK, start switch.
Note just because the fuse look OK does not mean that power is getting to the unit.
Check the voltage at the plug
L1 to L2 should be 240 volts
L1 to Neutral (motor voltage) and L2 to Neutral, both should be 120 volts.
If OK
If OK
[COLOR="Red"]Be careful as 240 volts is lethal !!! [/COLOR]
4. When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset.
