chenrezig12
#1 Posted : Thursday, August 4, 2011 2:10:46 PM(UTC)
chenrezig12
There is just nothing. Are there fuses beside the thermal fuse? What about the door switch. Do they go out a lot? What specific things would just kill the power? Checked box out side fuses were fine.
#2 Posted : Friday, August 5, 2011 4:16:42 AM(UTC)
Replacement parts for WHIRLPOOL LEC5000PQ0 29" ELECTRIC DRYER | AppliancePartsPros.com
[COLOR="DarkRed"]
Are there fuses beside the thermal fuse?[/COLOR]
Yes. There is a thermal cut off but it is located on the heater and will not effect the unit starting.
I am assuming then that you have checked the thermal fuse on the blower.
This could be the problem. They do not go out a lot but that does not mean yours is OK.
First check that the switch is being activated when the door is closed.
Next unplug the unit and check the switch with a meter.
If OK, then check the push to start switch.
Could also be the motor itself, the timer contacts BU/BK, start switch.
Note just because the fuse look OK does not mean that power is getting to the unit.
Check the voltage at the plug
L1 to L2 should be 240 volts
L1 to Neutral (motor voltage) and L2 to Neutral, both should be 120 volts.
If OK
If OK
[COLOR="Red"]Be careful as 240 volts is lethal !!! [/COLOR]
4. When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset.
File Attachment(s):
LEC5000.pdf (333kb) downloaded 3 time(s).
Dryer won't start. Changed all thermostats and fuse (Dryer Repair)
Belarus rudekelly 4/23/2014 6:55:22 PM(UTC)
Whirlpool gas dryer won't start. Fuse is good (Dryer Repair)
by jeffmaaske 7/17/2012 8:38:23 PM(UTC)
Dryer won't start. Buzzes loudly when start pressed. (Dryer Repair)
by Spoiler9112 9/4/2010 1:48:30 PM(UTC)
dryer won't start. Timer is just clicking (Dryer Repair)
by dohboy30 11/28/2009 11:19:12 AM(UTC)
Dryer won't start...buzz sound (Dryer Repair)
by RockyRocks 6/3/2009 5:20:01 PM(UTC)
Dryer won't start. (Dryer Repair)
by Rick L. Gardner 4/30/2009 12:26:11 PM(UTC)
by kayleediane 4/28/2009 5:54:41 PM(UTC)
Maytag dryer won't start....... (Dryer Repair)
by ShaNene 3/4/2009 8:40:55 AM(UTC)
Roper Dryer won't start... (Dryer Repair)
by deanna08 12/18/2008 1:57:56 PM(UTC)
Whirlpool Electric Dryer won't start. (Dryer Repair)
by tangomacaw 12/5/2008 5:00:59 PM(UTC)
