professor007
#1 Posted : Friday, April 15, 2011 5:25:10 PM(UTC)
professor007
I am trying to replace a lid switch, part number 3949237 which has been replaced with part number 3949247. The difference is the wiring plug that plugs into the control panel are different. The old one has square terminals, and the new one has round ones. I have tried to find the old part, and cannot. I have taken it apart, and had new one installed until I noticed the difference, any ideas?
sidfink43
#2 Posted : Sunday, April 17, 2011 5:39:45 PM(UTC)
sidfink43
There are different plug ends on these switches. Get back with the seller and get them to send you to right one.
If all else fails, and it shouldn't, you can also cut off the plugs, strip the wires and wire it in direct. Just make sure you get the right wires together and that the connection is done professionally with a crimping tool and connector.
How to remove terminals from Kenmore washer lid switch connector (Washer Repair)
by NCRX 8/25/2015 2:14:33 PM(UTC)
Washer Lid Switch (part #3949247) (Washer Repair)
by YZT 12/8/2014 5:55:02 AM(UTC)
Washer Lid Switch (Washer Repair)
by souljoe 11/20/2014 4:48:08 PM(UTC)
Maytag washer lid switch (Washer Repair)
by Anki 2/25/2014 4:13:32 PM(UTC)
fuse on replacement washer lid switch assembly (Washer Repair)
by flmikee 12/25/2013 7:02:54 AM(UTC)
maytag washer lid switch (Washer Repair)
by krissoto 6/1/2013 5:22:37 PM(UTC)
Kenmore Washer Lid Switch - model number on replacement rubbed out (Washer Repair)
by duplex 5/9/2013 7:21:06 AM(UTC)
Washer lid switch wires (Washer Repair)
by bonnie2003 9/15/2011 4:01:01 PM(UTC)
by xyz334 6/9/2011 11:52:40 AM(UTC)
Washer lid switch (Washer Repair)
by xyzabc 5/25/2011 8:32:52 PM(UTC)
Whirlpool washer lid switch assembly (Washer Repair)
by Mailman83 6/24/2010 4:54:39 PM(UTC)
by repairtodoer 2/11/2010 12:28:53 PM(UTC)
Stackable washer lid switch replacement (Washer Repair)
by tmealy 8/18/2009 10:22:32 AM(UTC)
by FayeP 7/27/2009 12:59:51 PM(UTC)
Whirlpool washer lid switch replacement (Washer Repair)
by lordmandy 7/27/2009 5:50:25 AM(UTC)
