FayeP
#1 Posted : Monday, July 27, 2009 12:59:51 PM(UTC)
FayeP
The lid switch came loose under the top of the washer cabinet. I have pulled apart the washer and retrieved the switch. However the 2 pcs of plastic that hold together the plastic axle with the spring won't stay together. I need a diagram of how the switch is suppose to be and how to connect the 2 pcs together???? And then reconnect under the cabinet top. Thanks
sidfink43
#2 Posted : Monday, July 27, 2009 1:24:48 PM(UTC)
sidfink43
Hi Faye
I cannot get your model number to come up, but I am going to assume you have the regular direct drive Kenmore/Whirlpool top load washer.
Anyway, we don't repair lid switches, we replace them. They are not expensive and this way you are sure of curing the problem. I assume you have taken off the cabinet, but if not here is a site which will show you how.
Kenmore top loader blues ‎(SublimeMasterJW's Appliance Advice)‎
After you get your new switch there are two screw which hold it in place to the top of the cabinet, and the plastic connector will come through (well, you will see on that site)
Good luck, if you need more info check your model number and post any questions.
How to remove terminals from Kenmore washer lid switch connector (Washer Repair)
by NCRX 8/25/2015 2:14:33 PM(UTC)
Washer Lid Switch (part #3949247) (Washer Repair)
by YZT 12/8/2014 5:55:02 AM(UTC)
Washer Lid Switch (Washer Repair)
by souljoe 11/20/2014 4:48:08 PM(UTC)
Maytag washer lid switch (Washer Repair)
by Anki 2/25/2014 4:13:32 PM(UTC)
fuse on replacement washer lid switch assembly (Washer Repair)
by flmikee 12/25/2013 7:02:54 AM(UTC)
maytag washer lid switch (Washer Repair)
by krissoto 6/1/2013 5:22:37 PM(UTC)
Kenmore Washer Lid Switch - model number on replacement rubbed out (Washer Repair)
by duplex 5/9/2013 7:21:06 AM(UTC)
Washer lid switch wires (Washer Repair)
by bonnie2003 9/15/2011 4:01:01 PM(UTC)
by xyz334 6/9/2011 11:52:40 AM(UTC)
Washer lid switch (Washer Repair)
by xyzabc 5/25/2011 8:32:52 PM(UTC)
by professor007 4/15/2011 5:25:10 PM(UTC)
Whirlpool washer lid switch assembly (Washer Repair)
by Mailman83 6/24/2010 4:54:39 PM(UTC)
by repairtodoer 2/11/2010 12:28:53 PM(UTC)
Stackable washer lid switch replacement (Washer Repair)
by tmealy 8/18/2009 10:22:32 AM(UTC)
Whirlpool washer lid switch replacement (Washer Repair)
by lordmandy 7/27/2009 5:50:25 AM(UTC)
