mnbaird
#1 Posted : Wednesday, October 24, 2007 4:47:01 PM(UTC)
mnbaird
Last year the latch broke on the soap dispenser. I replaced it and since then the lid will not open to release the soap. I bench tested the solenoid that actuates the latch and it works fine. The other issue I am having is that I get a message LO at the end of the cycle saying that the rinse aid is empty even when it is full. So today I replaced the main control board hoping it would cure these issues. But it didn't. HELP! Any input or suggestions would be appreciated.
#2 Posted : Wednesday, October 24, 2007 5:54:13 PM(UTC)
Hi mnbaird
The first thing I would do is to check wires inside the door.
mnbaird
#3 Posted : Wednesday, October 24, 2007 6:19:29 PM(UTC)
mnbaird
I have visually looked at the wires and connections. They all look good. Is there anyway I can go into a diagnostics mode and actuate the solenoid through the control panel to see if it is getting an electrical signal?
#4 Posted : Wednesday, October 24, 2007 6:23:12 PM(UTC)
All technical data suppose to be inside the control panel or inside the door.
richappy
#5 Posted : Thursday, October 25, 2007 1:11:17 AM(UTC)
richappy
I fixed one once, soap contaminated the electrical connections at the door latch connector and the timer pins. I just pushed on the pins and it worked. You might try non-residue spray on the timer and connectors and push all the pins in the connectors.
Guest (6)
Kitchenaid Dishwasher soap dispenser won't open during cycle (Dishwasher Repair)
by dawnbeaufort@gmail.com 12/18/2015 3:22:47 PM(UTC)
maytag soap dispenser won't open (Dishwasher Repair)
by jjleip11 9/15/2013 1:44:50 PM(UTC)
Bosch dishwasher soap dispenser won't open (Dishwasher Repair)
by jbuckley1 1/19/2012 5:55:14 AM(UTC)
Whirlpool Dishwasher Soap Dispenser Won't Open During Cycle (Dishwasher Repair)
by Dr_Zoidberg57 9/1/2010 11:22:54 AM(UTC)
Soap Dispenser Won't Open (Dishwasher Repair)
by hcover7 11/10/2009 2:37:19 PM(UTC)
by chwu999 5/18/2008 8:56:09 PM(UTC)
by Badnews 5/11/2008 7:13:35 PM(UTC)
Soap dispenser won't open (Dishwasher Repair)
by renochick 1/9/2008 5:42:32 PM(UTC)
