The soap dispenser will not open during wash cycle. It will open manually, but not electrically.
What's best way to tell if it's soap dispenser or not?
I need to replace the soap dispenser but am unable to remove the top screw. The screw will turn but will not screw out so something is blocking its removal. I was hoping to drill it out, but don't know what is behind it (hoping it just a area where a screw goes) I believe this was a factory error as I've never tried to remove this inner door panel before. Any help would be greatly appreciated. Chris Devoe chrisdevoe@cs.com
