Alexander-113
#1 Posted : Monday, January 5, 2009 1:51:23 PM(UTC)
Alexander-113
Heating element has distorted inside my dishwasher at the left rear corner and burned through the casing. While this corner distorted downwards, the right side past the retaining clips is bowed upwards as is the front side of the element. Nothing fits through the rack grate that can exert enough pressure to bend the element. Additionally, all dishes were clean which means that nothing was blocking the movement of the washer arm during the cycles. Has anyone ever heard of an element distorting and what could have caused it?
#2 Posted : Tuesday, January 6, 2009 3:50:38 AM(UTC)
Could find no info using given Model Number though I do not think it really matters.
Sounds like the temp thermostat and/or the over temp thermostat did not open when it should have. On top of this the timer may have stuck during a dry cycle.
Also the heater may have had a hot spot.
In any case by the sound of it the unit is toast.
Kenmore 100 dryer Heating Element (Dryer Repair)
by postalservice21 3/27/2024 6:43:17 AM(UTC)
Oven Heating Element Wire Repair (Oven Repair (including Ranges and Cooktops))
by JT5 11/22/2023 5:20:00 AM(UTC)
Left side heating elements (Oven Repair (including Ranges and Cooktops))
by Guest 11/19/2023 10:24:48 AM(UTC)
Whirlpool oven - only one heating element? (Oven Repair (including Ranges and Cooktops))
by smithhead 11/3/2023 2:42:01 PM(UTC)
Heating element won't turn off on Maytag dishwasher (Dishwasher Repair)
by Guest 8/2/2023 6:10:10 AM(UTC)
new heating element, but still not heating (Dishwasher Repair)
by ScotofBV 7/13/2023 5:47:30 PM(UTC)
A blue wire going to heating element in freezer is blown (Refrigerator & Freezer Repair)
by Guest 6/5/2023 1:14:06 PM(UTC)
Frigidaire Dishwasher Heating Element warped? (Dishwasher Repair)
by Guest 4/8/2023 10:48:21 AM(UTC)
Miele (4882) Lower Heating Element (Oven Repair (including Ranges and Cooktops))
by drmoose00 3/22/2023 7:09:47 PM(UTC)
Electrolux range (2008) -heating element won't turn off (Oven Repair (including Ranges and Cooktops))
by xain1z2z 3/19/2023 1:21:18 PM(UTC)
Whirlpool Stove working but both heating elements are not (Oven Repair (including Ranges and Cooktops))
by Guest 2/20/2023 1:06:16 PM(UTC)
Oven wall heating Element broke while cooking (Oven Repair (including Ranges and Cooktops))
by Guest 9/12/2022 1:21:34 PM(UTC)
Dishwasher heating element wont shut off (Dishwasher Repair)
by dperna 2/23/2022 12:20:33 PM(UTC)
LG WM3050C thermistor/heating element help (Washer Repair)
by Guest 10/2/2021 5:29:07 AM(UTC)
Heating element will not shut off (Oven Repair (including Ranges and Cooktops))
by Guest 8/13/2021 8:50:42 AM(UTC)
