I have a Frigidaire model number gpdb998jc1 that is about 10 years old. Dishes dont seem to get clean. Soap dispenser doesnt seem to get cleaned as well. I cleaned out the drain and no obstructions or dirt.
A few months ago, I replaced the the water inlet valve. Not sure if that did anything.
As it goes through its normal wash cycle, I hear the water filling up the bottom of the tub. As it continues in the cycle, I dont hear the water spraying around the sides of the appliance. I hear the motor running but doesnt sound as quiet as it used to.
Any help would be appreciated!
THIS FORUM IS DEAD!!!!!!! |
thanks very much for the help! Will check it out and see if it works
